Auctions
Rebel Wiring Harness - Rewire your Rod or Kustom
Discussion in 'Parts For Sale' started by dt50chev, Sep 22, 2014.
  1. dt50chev
    dt50chev
    City: Temple
    State: TEXAS!
    Price: $127 & up
    Wiring harness kits from Rebel Wire. All kits are new and made in the USA. 10% discount for all HAMB members. We accept PayPal and Credit card orders. Call or email to order. (254)718-3842. [email protected]
    Rebel Wire 8 Circuit Wiring Harness
    $169.95
    Rebel Wire harnesses are all assembled in America from American made components. The 8 circuit wiring harnesses is perfect for Hot Rod, Rat Rod, T-Buckets, or Custom applications that require only basic circuits.
    Assembled with heavy duty SXL wire labeled every 6" and bundled for easy
    installation. This kit has 8 circuits for lights, gauges, radio, motor and third brake light. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, and fuse block label.
    Rebel Wire 9 + 3 Circuit Wiring Harness
    $189.95
    The Rebel Wire 9 + 3 circuit wiring harness is perfect for your hot rod, street rod,custom or muscle car applications that require fewer circuits. Assembled in American from American made components, the heavy duty SXL wire is labeled every 6" and bundled for easy installation. This kit has 9 circuits for lights, gauges, radio,
    ac-heat, motor, and third brake light, plus 3 open circuits for whatever you might want to add such as power windows and doors, electric fan, etc. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, 3 fuse block terminals and fuse block label.
    FUSE BLOCK
    $134.95
    14 CIRCUIT FUSE PANEL WITH POWER LEADS.
    MADE FOR CUSTOMERS WHO WANT TO CUSTOM WIRE THEIR CAR BUT DON'T KNOW WHERE TO START. CIRCUITS INCLUDE: HORN, H L POWER, BRAKE LIGHTS, TURN SIGNAL, HAZARDS, RADIO CONSTANT, CELL PHONE CHARGER, TRUNK LIGHT, DOME LIGHT, GAUGE POWER, RADIO, A/C HEAT POWER, WIPER POWER AND 2 SWITCHED ACCESSORIES.
    *TURN SIGNAL, HAZARD FLASHERS & HORN RELAY INSTALLED IN FUSE PANEL
    Rebel Wire 14 Circuit Wiring Harness
    $211.00
    The REBEL WIRE 14 Circuit wiring harness gives you a great mid-range kit at an affordable price. Kit has circuits for lights, gauges, radio, ac-heat, wipers, turn signals, hazard 4-way, horn, power windows, electric fan,cell phone charger. Assembled with heavy duty SXL wire and labeled every 6" and bundled for easy installation.
    Rebel Wire 16 Circuit Wiring Harness
    $220.00
    16 Circuit wiring harness designed for Chevy, Ford, Mopar and other 60's and 70's cars and trucks. Kit has the following circuits: Horn relay, Headlights 2 or 4, Hazard, Cell phone charger, Dome and Trunk Lights, Radio and Radio Constant, Gauge Power, Wiper, Brake Light,3rd Brake Light, AC-Heat. Turn Signal, Elec. Choke and 1 Accessory wire, Fusible Link and Rubber Grommett.
    All our kits are manufactured using heavy duty SXL wire and labeled every 6". All kits come with easy to follow instructions and Tech Line info.
    Rebel Wire 21 Circuit Wiring Harness
    $239.95
    This Rebel Wire 21 Circuit takes the Basic Muscle Car Harness then we added Power Doors, Power Windows, Power Seats, Cruise and Electric Fan Relay Control wire. Assembled with heavy duty SXL wire labeled every 6" and bundled for easy installation. Comes with Fusible link, 1 1/4 Rubber grommet for firewall. Instructions and Fuse Label.
    Rebel Wire 6 VOLT Universal Wire Harness
    $260.00
    8 Circuit, Includes: horn, headlights, stop light, heater, radio, gauge power, turn signal and wipers. Wire is SXL, all sized for 6 Volts, labeled every 6" as found in all REBEL WIRE kits. Turn signal flasher in fuse panel. Horn relay separate. Wires car or truck from front to rear.
    Rebel Wire 8 Circuit REAR FUSE MOUNT KIT
    $299.95
    8 Circuit Rear Fuse Mount Wiring Kit
    These are the kits everyone has been asking for. You can mount the fuse panel in the Console, Under Seat or in the Trunk, within 12' of the Dash.
    Rebel Wire 9+3 Circuit REAR FUSE MOUNT KIT
    $319.95
    These are the kits everyone has been asking for. You can mount the Fuse Panel in the Console, under Seat, or in the Trunk, within 12' of Dash.
    Rebel Wire 21 Circuit REAR FUSE MOUNT KIT
    $419.00
    Rebel Wire VW Bug Universal Harness -12 Volt
    $219.95
    12 Circuit
    Horn Relay, Brake Lights, Head Lights, Hazard, Turn Signal, Cell Phone charger, Radio, Gauges, AC-Heat, Back up Lights, Wiper, Coil.
    Pre-Wired 8-fuse panel, now with 3 Prong Turn Signal Flasher.
    Assembled with Heavy duty SXL wire and labeled every 6" and bundled for easy installation.
    Rebel Wire V.W. BUG DELUXE Wiring Harness
    $240.00
    16 Circuit universal harness, Horn Relay, Lights, cell phone charger, Hazard, Gauge Power, Wiper, Brake Lights, AC-Heat, Back-up,Radio Constant, Turn signal, Dome light, Trunk Light and 2 Accessory Circuits both Keyed.
    12 Fuse panel with 3 prong flasher and Horn Relay.
    Assembled with heavy duty SXL wire, labeled every 6" and bundled for easy installation.
    Rebel Wire - VW BUS Universal Harness - 12 Volt
    $249.95
    14 Circuit, Horn relay, Headlights, Hazard, Cell Phone charger, Gauge power, Wiper, Brake Lights, AC-Heat, Back up, Radio, Turn Signal, ACC 1 Keyed, ACC2 Keyed, ACC 3 Hot.
    12 Fuse Panel with 3 prong flasher and horn relay.
    Rebel Wire - V W Rail Buggy - 4 circuit Hot Rod Kit
    $136.95
    Rebel Wire Rail Buggy harness includes wiring for Head Lights, Tail Lights, Turn Signals, Horn, Gauges and Accessory Wire.
    THIS KIT IS FOR A BASIC RAIL BUGGY, Glass body buggys should use BUG HARNESS
    Small 4 fuse panel with horn relay and flasher.
    Assembled with Heavy Duty SXL wire and labeled every 6". Bundled for easy installation.
    Perfect for a Basic Hot Rod, T-Bucket, or Dune Buggy
    Rebel Wire 9 + 3 Muscle Car Wiring Harness
    $209.95
    This kit is the same as the 9+3 Circuit but we have added 4 headlight connectors and wiring and the side marker light.
    Rebel Wire 16 Circuit American Muscle Car Wiring Harness
    $240.00
    Basic Muscle car harness designed for Chevy, Ford, Mopar and other 60's and 70's cars and trucks. Kit has the following circuits: Horn relay, Headlights 2 or 4, Hazard, Cell phone charger, Dome and Trunk Lights, Radio and Radio Constant, Gauge Power, Wiper, Brake Light,3rd Brake Light, AC-Heat. Turn Signal, Elec. Choke and 1 Accessory wire, Fusible Link and Rubber Grommett.
    All our kits are manufactured using heavy duty SXL wire and labeled every 6". This kit includes 4 Headlamp connectors and wires for side marker lights. All kits come with easy to follow instructions and Tech Line info.
    Rebel Wire 21 Circuit American Muscle Wiring Harness
    $260.00
    This Rebel Wire 21 Circuit takes the Basic Muscle Car Harness then we added Power Doors, Power Windows, Power Seats, Cruise and Electric Fan Relay Control wire. This kit comes with connectors and wire for 2 or 4 headlamps and wire for side markers. Assembled with heavy duty SXL wire labeled every 6" and bundled for easy installation. Comes with Fusible link, 1 1/4 Rubber grommet for firewall. Instructions and Fuse Label.
    SUNBEAM, ALPINE/TIGER WIRING HARNESS
    $319.95
    Now available a Universal Replacement Harness. Fuse Panel Mounts on Inner Fender in stock location. Headlights are run thru relays, all lights, ac heat, wiper, gauges, elec fuel pump, electric choke, radio, radio constant-cell phone charger and 1 accessory wire.
    Rebel Wire 8 Circuit RIGHT HAND DRIVE Wiring Harness
    $199.95
    THIS HARNESS IS FOR RIGHT HAND DRIVE VEHICLES ONLY
    Mopar Engine Harness
    $215.95
    Rebel WIRE 9+3 Circuit RIGHT HAND DRIVE Wiring Harness
    $199.95
    The Rebel Wire 9 + 3 circuit wiring harness is perfect for your hot rod, street rod,custom or muscle car applications that require fewer circuits. Assembled in American from American made components, the heavy duty SXL wire is labeled every 6" and bundled for easy installation. This kit has 9 circuits for lights, gauges, radio, heater, motor, and third brake light, plus 3 open circuits for whatever you might want to add such as power windows and doors, electric fan, etc. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, 3 fuse block terminals and fuse block label.
    THIS IS FOR RIGHT HAND DRIVE VEHICLES ONLY
    Rebel Wire 14 Circuit RIGHT HAND DRIVE Wiring Harness
    $221.00
    Rebel Wire 16 Circuit RIGHT HAND DRIVE Wiring Harness
    $230.00
    Rebel Wire 21 Circuit RIGHT HAND DRIVE Wiring Harness
    $249.95
    The Rebel Wire 21 circuit wiring harness is perfect for the highly optioned street rod, custom or muscle car. Assembled in American from American made components, the heavy duty SXL wire is labeled every 6" and bundled for easy installation. Circuits are provided for all the basics, (lights, gauges, radio, and motor), plus AC, power windows and doors, electric fan, electric fuel pump, trunk light, dome light, electric choke, radio constant, cruise, backup lights, tach, cell phone charge and third back light. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1/4" rubber grommet for the firewall, and fuse block label.
  2. dt50chev
    dt50chev
    Bump
    Baron likes this.
