Technical Rear Wheel Seals
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, Apr 3, 2020.
  1. Hdonlybob
    Hdonlybob
    I have forgotten much lately (at 76) but rely heavily on a good friend that also has classic car shop.
    I had him do my annual oil/grease/fluids/etc check this week on my '63 Biscayne.
    He called me and told my the rear wheel seals were just starting to leak...to which I told him go ahead and change them.
    Paid for it yesterday and was kinda surprised that he also changed the rear wheel bearings...
    He told me it is pretty much necessary to do this..
    I have no objection, just curious...
    Thanks much.
  2. 325w
    325w
    You got a good mechanic taking care of your car. He did right.
  3. manyolcars
    manyolcars
    I bet you are talking about rear axle shaft seals
    lothiandon1940 and Hdonlybob like this.
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    Worn bearings are usually the first thing to start seal wear. Your friend did the right thing by replacing them.
    mgtstumpy and lothiandon1940 like this.
  5. Mike VV
    Mike VV
    from SoCal
    Um...the "wheels" have...seals..?
    Where have I been, I didn't even know that wheels HAD...seals.
    Mike
  6. Hdonlybob
    Hdonlybob
    Thanks much,
    Pretty much what I remembered from years back...
    Sad that I can no longer do this stuff myself..but hey, I still can enjoy driving it :)
    Max Gearhead likes this.
  7. Axle shaft seals on passenger car rear axles and wheel hub oil seals on full floating rear axles.
  8. squirrel
    The seals are part of the wheel bearing assembly on those cars. So yeah, he had to change the bearings to replace the seals.
    porknbeaner likes this.
  9. Jim, I just looked on Rock Auto, it looks like the seal is part of the bearing? Does the bearing press on to the axle shaft, like a Ford 9 inch?
  10. squirrel
    The seal is part of the bearing. The bearing is pressed on the axle shaft.
    64 was the last year of that in most Chevy cars.
    porknbeaner and Truckdoctor Andy like this.
  11. Hdonlybob
    Hdonlybob
    Yep Yep...I didn't realize they were pressed on...
    My friend told me that yesterday when I was harassing him about my wife saying she was sick of him taking vacations on us.. lol
    It is ongoing every time I do something to my Biscayne.....
  12. 41rodderz
    41rodderz
    from Oregon
    We all have to “pay to play “ wether we do it all ourselves or have some one else doing it. Roll on and enjoy .:)
    Hdonlybob likes this.
  13. blowby
    blowby
    from Nicasio Ca
    I put one new bearing on today before realizing the two bearing sides are different. One side has a seal with an external spring on the inside race, the other side has a flat seal with no spring. Which way do the go?
    Bet I got it wrong...
  14. squirrel
    The seal is to keep the gear oil out of the wheel bearing, which has grease in it. So....seal in....right?
  15. blowby
    blowby
    from Nicasio Ca
    Yep sounds good. And the other side probably has an internal spring to keep the grease in, and out of the brakes. Thanks. I would have figured this out on my own if I was't exhausted from getting the old bearings off, what a pain.
    First time I've dealt with sealed rear axle bearings. All I've done just just use the rear end lube. Why sealed bearings?
  16. 325w
    325w
    The grease follows the axle to the outside of the housing. By turning the grease gets to the axle bearing then it can leak as the bearing wears
  17. Cree
    Cree
    from Montana
    Hopefully not hijacking here, taking opportunity for a possibly related question:
    My Model A's 9" rear has cast housing ends with no provision for internal seal, requiring bearings with an o-ring seal. A new set of axles came with Strange A1021 o-ring bearings installed that had an outer sealed side and an inner side open to the gear lube which seemed odd. The bearings were initially packed with grease. A tech at Strange said these are "drag race only" bearings, which I understood to mean not for heavy side loading. After running a few months, I have a leak on one side and intend to replace the o-ring (plus a little sealant). Anyone have experience with this bearing setup?
