ive been having issues with my rear spring on the roadster(29 on a 32chassis)! Can't get the t spring to work( stiff) to wide to work the schakels. Thinking of going to coil overs. Any body give me suggestions on which coil over spring weight. Thanks
Here are a couple of posts I saved. I hope they may be of some help to you. Remember it is spring rate but also angle of setup.
Brian did a huge tech thread years ago that I saved for future use and it is a good long read but it may enlighten you as to what is available and how he handles the ride in his builds. Here is the link to his thread https://www.jalopyjournal.com/forum/threads/how-to-build-an-early-hotrod-frame.150434/
If you are looking for a softer ride and want to keep using a rear spring, there is a lot of info on using the '35-'40 Ford front spring on the rear. I did that on the '29 on a '32 style frame I'm building. Depending on what stage your car is at, it may be more work than you'd care to tackle.
Stock spring. Shackles are straight up . Tried removing leafs and cutting some for a better ride. No luck with that. Need a spring that would be narrower eye to eye than I have. I have a q c so I need a spring to stay out of the way of that .Bushing are speedway
Robert,if you end up going with coil overs check out the QA-1 shocks,they have a knob for adjusting the ride quality,I recently replaced the ancient TCI coil overs on my sedan and the ride is greatly improved. HRP
A HAMB member makes model t rear springs with model a specs. I see them advertised in the classifieds
