Rear spring and ride hight
Discussion in 'The Hokey Ass Message Board' started by Devin, Sep 25, 2014.
  1. Devin
    Devin
    from Napa, CA
    I have a '40 rear spring on the back of my model a. The suspension has settled some and one of the spring mounting bolts is just barely rubbing the pumpkin. I have an extra '40 spring and was wondering which leaves I could add to raise the spring rate and. keep the spring from spreading so much. The shackles used to be at a nice 45 degree angle and now they are mor like a 75 degree angle. The spring mounting perches are 48" center to center. Also would longer shackles help or make the problem worse? Thanks
  2. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
    Crazy question, but couldn't you just re-arch the spring?
  3. Devin
    Devin
    from Napa, CA
    I haven't ruled that out, I was wondering if anything could be done with what I have on hand right now.
