rear problem
Discussion in 'The Hokey Ass Message Board' started by metal bender, May 13, 2009.
  1. metal bender
    metal bender
    from texas
    Put a blazer rear in with a 350 turbo 3spd in high or 3rd it feels like its in 2nd gear , was the rear meant for a 4spd. ??? any one know ? 89 blazer rear
  2. squirrel
    Probably meant for overdrive. You didn't check the ratio first? now you know...
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Don't make any diff 3 or 4 speed,high is direct. If the Blazer was a standard trans the rear could be 3.50-3.70. Ya should have checked the ratio before ya put it in.
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    S-10 Blazer, or a big one? What was the original tranny? Hope its around 3.55 or so ratio.
  5. squirrel
    not if the 4 speed is an automatic....like the automatics they put in Blazers in 1989, which are all 4 speeds with overdrive
  6. metal bender
    metal bender
    from texas
    s10 and we dint check the ratio . oh crap
  7. squirrel
    Put a big cam in the motor and have fun
  8. metal bender
    metal bender
    from texas
    I, think you right 4 spd. auto was in the s10. Iam in deep shit right ?
  9. mottsrods
    mottsrods
    Well, if 3rd fells like second, then 1st and 2nd should get you there alot quicker.... just push the go pedal and don't reach for the dash!!!
  10. metal bender
    metal bender
    from texas
    The sob has a big cam you can go about 80 mph and back off the thing feels like your in 2nd gear !!! Better get the torch out !!
  11. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep I know 4 speed autos are OD. Was not spec'd weather std or auto. and far as that goes the exception was the early Hydros, 4 speed and direct.
  12. Oh heck no, low gears are fun! Low gears with a posi behind an engine that makes a good torque is = way fun! Sucks for prolonged highway speeds but a LOT of fun getting there.
