Technical Rear brake lockup
Discussion in 'The Hokey Ass Message Board' started by rockable, Feb 9, 2020.
  1. rockable
    rockable
    My 49 Chevy Wagon has a 57 Chevy rear end with stock drum brakes. The fronts are GM M calipers and there is a GM combination vale in the circuit. I'm almost certain the plumbing is correct because I corrected an error right after I bought the car. The car stops well but in a panic stop, the rears lock up and that is a scary proposition. Today, I had a close call while out for a drive.
    I will investigate this more thoroughly this coming week but, assuming all is plumbed correctly and the combination valve is ok, what other things could cause this? Adjustment of the rears? Pushrod from the booster to master cylinder too long? Help me get the possibilities fresh in my mind.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    Fronts not grabbing or wrong proportioning valve for brake hardware.
    firstinsteele likes this.
  3. rockable
    rockable
    The fronts are working and the GM combination valve is tried and true. I'm thinking that the rears may be heating up a bit and causing them to grab when pressure is applied.
  4. 6sally6
    6sally6
    Buy an ADJUSTABLE proportioning valve. They have a knob to change the bias from front to back. (s'why it's called adjustable.
    6sally6
    270ci, Elcohaulic, jimmy six and 4 others like this.
  5. bschwoeble
    bschwoeble
    Agree with 6sally6. Factory proportioning valves are specific to the car it came off of.
  6. rockable
    rockable
    I'm familiar with them but I've never had to use one before. The 57 brakes aren't all that stout, so I will check things out. Maybe someone put oversize wheel cylinders in the rear?
  7. MAD MIKE
    MAD MIKE
    from 94577
    Generic preset prop valves are only ideal for whatever vehicle they were based on.
    If your front brakes are 80's 'G' body 60mm metric calipers/10.5" discs, they were never paired with anything other than 9" drums on a framed car.
    Your '57 11" drums will rear bias the brake system. Even the 'G' wagons still sported the 9" drums.
    '57 rear wheel cylinders were 1" on the early cars, G bodies used 3/4"rear wheel cylinders. This again pushes the brake bias rearward.
    Get an adjustable prop valve and do some brake testing.
    The other thing is if you ever load up the car with people/cargo, you can adjust the brake bias rearward to improve loaded stopping performance. This always requires time/testing, but if you can load up the car with weights and readjust for every added 100lbs you can really improve the braking of your vehicle. Just mark the knob for each additional weight increase.
    270ci, rockable and David Gersic like this.
  8. rockable
    rockable
    Thanks. That makes one more thing I have to change on this car. The list seems endless.
  9. lippy
    lippy
    from Ks
    You love it and you know it. :D I feel your pain. Lippy
    rockable likes this.
  10. rockable
    rockable
    Actually, I am ready to just drive this one for a while. Plus, I hate dealing with brake fluid. Its the best paint remover ever made.
  11. lippy
    lippy
    from Ks
    I hear you on the driving part. Hope you get it sorted out. Love your Buick. I have a 47. Lippy
  12. This is the one I use, no braking problems. I have it wide open and have yet to adjust it. My rears are stock Ford, GM disc up front. prop valve.jpg
  13. ol-nobull
    ol-nobull
    Hi. On m 46 Chevy with original brakes the rear drums would lock up in a panic stop. Turned out the car had the original flex line between line on frame and the line on rear end. Turned out this neopreme? line was deteriating on the inside and it had a hanging flap inside and the pressure of a panic stop jammed it down and sealed of the line under pressure. Brakes would have to sit 15 - 20 minutes for the pressure to seep off and release. new flex line cured the problem. Jimmie
  14. 4274SPEED
    4274SPEED
    Had a similar problem once.I thought both rear wheels were locking but it turned out drivers side was . One of the brake shoe linings had become half unbounded from the shoe and would lock the drum when braked even slightly. On inspection everything looked fine. Threw me for a loop!
  15. 54vicky
    54vicky
    another possibility is the back linings being contaminated think leaking cylinder, grease from leaking seals.probably not the case but costs nothing more than time to eliminate the possibility
  16. rockable
    rockable
    Being as stubborn as I am, I pulled the rear drums and decided to replace the shoes. Went to O'Reilly's and picked up a set of rear shoes, Brake Best p/n 55. After comparing them, this is what I found. The shoes that are presently on the car have a typical short front shoe and a longer rear shoe, as you would find on most self adjusting drum brakes. The replacement shoes I bought are all the same length. I'm definitely going to try this before making hydraulic changes.
    Does anyone know if the rear shoes for the drop center Chevy rear ends, manual adjust, are supposed to be the same length?
  17. Mimilan
    Mimilan
    The 57 had narrower 1-3/4" shoes on the rear compared to 2" shoes on the front [even though they used the same sized 2" drums all round]
    Chevy stamped a different offset backing plate for the narrower rear drums so you cannot swap front shoes into the rear.
    They had a smaller friction surface on the front shoes.
    also
    Go and try your car on a slightly slippery surface and see which end locks up first.
    Less traction = Less G forces
    Less G forces = Less weight transfer onto the front.
    You might need a slightly smaller wheel cylinder to reduce clamping pressure.
    Manufacturers had the brakes proportioned for lower G force stopping ,then added a pressure limiting valve [proportioning valve] to prevent rear wheel lock up during "Oh F**** "moments.
    57 chevys do not have any proportioning valves, or residual valves in the system
    edit:
    If you proportioned the brakes correctly for panic stopping in dry conditions [as Road Racers do] , In the rain or other less ideal conditions you would have front wheel lock up Which is more dangerous
    you need to think from the tyre footprint backwards. It is at the limit of tyre adhesion where Fr/Rr bias problems rear it's ugly head.
  18. Mimilan
    Mimilan
    I hope this was a typo:)
    Using a smaller rear wheel cylinder decreases clamping pressure [it is the opposite effect to smaller M/C size]
    so going from 1" to 3/4" wheel cylinders pushes the brake bias forward.
    Which would be the desired result for the OP
  19. rockable
    rockable
    You are absolutely correct. That is why I take these recommendations with a grain of salt. Thanks!
  20. The short and long shoe setup is a feature of self-energizing brakes rather than self-adjusting brakes. Depending on what the current prop valve was used on originally, a 9" self-energizing rear drum setup might put everything right with the world for you. The front disks should provide most of the stopping force for you anyway.
    Or, as already mentioned, there's always the adjustable proportioning valve solution.
    Truckdoctor Andy likes this.
  21. rockable
    rockable
    I think I found the problem.
    wood remover and Elcohaulic like this.
  22. gene-koning
    gene-koning
    Yep, that would do it. Been seeing a lot of these worn brake shoe pads wore out in the last few years, do you think this 70 year old stuff is finally catching up with us?
    Been seeing it on front disc brake brackets as well. I was helping a friend that was complaining about his disc brakes dragging. We pulled the calipers off and the steel housing the brake pads rested against had nearly a 1/4" dip in them. I welded them back up, filed them flat, the the disc brakes no longer dragged. Gene
  23. V8 Bob
    V8 Bob
    Pretty sure '57s had an internal residual (check valve) in the master cylinder, like most if not all single system drum brake masters.
    Proportioning came along with front disc brakes in the mid '60s, although some drum/drum vehicles could have benefited with one.
    Why is front wheel lockup more dangerous than rear???
    427 sleeper likes this.
  24. Mimilan
    Mimilan
    If 55-57's had an internal residual (check valve) in the master cylinder , it must be very small. My M/C only has a single Flare Nut straight into the M/C casting.
    with the Brake lockup question! You need to talk to Road Racers.
    Those guys are at maximum braking at every corner entry. If they aren't, some young "hotshoe" will be passing them under the brake zone.
    Sure this is competition , but in the real world an emergency braking situation is the same [Road Racers get to practice it more often[​IMG]]
    Wheel lock-up is equal No brakes for that particular wheel [except minor tyre/road friction]
    Tyres don't work on co-efficient of friction they Grip which is why G forces exceeding 1. are possible without downforce.
    If for example you do a panic stop that causes 25% weight transfer to the front [on a 50/50 balanced car] The front brakes now have 75% braking and the rears only 25%.
    If the front locks up you lose 75% braking .
    As for the rears locking up first causing cars to spin out?
    The most efficient braking is not on a corner where a tyre is trying to control lateral acceleration and deceleration in the same tyre footprint .
    The saying is "Brake on the Straight before it's too Late"
    Elcohaulic and rockable like this.
  25. V8 Bob
    V8 Bob
    The residual check valve is located internally and at the end of the bore on single system masters.
    On the street, fronts should always slide before the rears. Really best not to have any sliding for the best braking performance. :)
  26. Driver50x
    Driver50x
    Sometimes machining the brake drums can help. I’ve seen both out of round and tapered drums cause grabbing and locking up problems.
  27. Mimilan
    Mimilan
    Your answer got me thinking/ worrying.
    I was given an almost new rebuilt / exchange M/C from a recently imported 55 Chevy. Because this particular car had modified brakes NZ law requires a dual M/C.
    This M/C was dismantled and there wasn't a residual check valve at all.
    Maybe for some reason, most rebuilt or new replacement master cylinders for these applications no longer have the residual valves.[ I don't know ]
    My car might or might not have one [I doubt if the M/C is original] but it works perfectly with no leaks or pedal travel issues.
  28. V8 Bob
    V8 Bob
    Below is a picture off the internet of a '55-'57 rebuild kit. The residual is located inside the big end of the spring on the right.
    Residuals are needed on vintage drum brakes to prevent air from entering past the wheel cylinder cups during release. They were used up until the mid '70s when front discs and wheel cylinder cup expanders made them obsolete. I still use them on newer drums to minimize pedal travel.
    rockable and 427 sleeper like this.
  29. Elcohaulic
    Elcohaulic
    Bob, how do residual valves minimize brake travel?
    I might need them on my el Camino. The stock GM Disc / drum brakes work perfectly but the pedal travel is deep.. This is the first car I ever had that didn't have a lot of disc brake drag...
    Thank you
  30. V8 Bob
    V8 Bob
    A residual keeps the line charged with fluid under very low pressure, minimizing the additional fluid needed to move the wheel cylinder piston(s), along with pedal travel.
    ClayMart, Elcohaulic and 427 sleeper like this.
