I have a 9 inch rear brake drum with 3.146 overall depth it is 12 11/16 of 11 inch brakes center register hole 2.430 numbers on the drum are KH 1238 13 41669 I can't find what they fit mine are warped and of in need of two. thanks Trammel
The KH stands for Kelsey Hayes, the manufacturer . Try googling Kelsey Hayes and the number Sent from my iPhone using Tapatalk
Drum for a nine inch Ford rear axle or a drum that is nine inches in diameter? I'm an old brake and front end guy and if you tell me you are looking for a nine inch drum my brain says that is pretty little and fits a small car. On the other hand an 11 inch ID drum with a swept surface that is wide enough for maybe 2-1/2 inch brake shoes shouldn't be that hard to figure out. What bolt pattern?
