Technical Rear axle gears?
Discussion in 'Traditional Hot Rods' started by Narum5, Feb 24, 2020.
  1. Narum5
    Narum5
    Got a 48 59A-B flathead with a c4 transmission with 35inch tall tires. What’s a gear ratio I should be looking for in an axle. For a 30 model A Tudor Show car. Can only drive it 6 months out of the year. (Live in the upper Midwest) don’t see myself driving this thing on the interstate much. 60-65 cruising speed. Thanks in advance.
  2. 55styleliner
    55styleliner
    A 35” tire turns 593 revolutions per mile. 60 miles per hour is 1 mile per minute. So if you take 593 and multiply it by your gear ratio, you get your RPM at 60 if you have a 1:1 final transmission ratio. For example, if you have a 3.50 rear gear, 3.50 x 593 = 2076 rpm at 60mph.
    ted kovacs and Narum5 like this.
  3. studebakerjoe
    studebakerjoe
    Might want to add what sort of car its in and more specifics about that flathead.
    Just Gary likes this.
  4. Boneyard51
    Boneyard51
    Car don’t make any difference, he gave the engine, transmission and tire height! The only thing he didn’t give.... and it’s important!! What is your optimum speed? With out that it cannot be figured!
    Bones
    kevinrevin likes this.
  5. Mike VV
    Mike VV
    from SoCal
    Ah yes...the ol..."lack of details" post..!
    Is this -
    1. A show car that won't get driven much ?
    2. Is this a weekend cruiser that will be driven around town ?
    3. Is this a car that will see many freeway miles ?
    4. Is this a car that will be making long freeway trips ?
    5. Going drag racing ?
    6. Making trips down the Bonneville Salt Flats ?
    Etc., etc.
    Mike
    Just Gary and lothiandon1940 like this.
  6. 19Fordy
    19Fordy
  7. Desmodromic
    Desmodromic
    Engine modifications, or more specifically HP ratings, are a key consideration. Too high a ratio (low numerically) could result in necessity to downshift on a slight grade, or worse yet, lower top speed in high gear than the next lower gear. Also, 35" tire diameter seems awfully large. Typically, stock Fords with V8s used a 3.78 ratio, with 28" diameter tires. Multiplied by the wheel diameter ratio gets you to a ratio of about 4.7 for reasonable drivability. Most Model As were 3.78, or optional 4.11. A very few had 4.56 ratio; good luck finding one!
    Boneyard51 and Just Gary like this.
  8. Narum5
    Narum5
  9. Mr48chev
    lothiandon1940 likes this.
  10. Boneyard51
    Boneyard51
    I understand the engine makes a difference, but he already stated he had a Flathead with a C-4 Auto. Chances are he has or is going to have a modern rear end. The most important thing he left out was the optimum driving speed. With the little info he provided, we already know this is probably not a real high performance engine, or he would have stated that fact. We know he has slippage with the C4 and tall tires. You are going to have to turn that Flathead a little higher that a larger V-8 in order to get enough horsepower to pull the car and C-4. So the rpm we should shoot for at his speed should be around 2800 to 3200+ at high cruising speed. Which he didn’t tell us. Definitely not enough info to answer!
    Bones
