Reamer info needed
Discussion in 'The Antiquated' started by quickrack-alan, Jan 24, 2021.
  1. quickrack-alan
    quickrack-alan
    from Ireland
    I am slowly gathering the front end parts for my hotrod. And of course it will need the kingpins done. But my question is, what reamer do I need? I live in Ireland where everything is in metric. I'll be fitting '32 spindles.
    Sent from my SM-A202F using Tapatalk
  2. Dave G in Gansevoort
    from Upstate NY
    Just a suggestion: Take the spindles to your local machine shop/engineering shop and have the bushings honed to fit the new pins. They should have a machine like this: 20200930_161200.jpg Hopefully much newer (this one is from 1928) but they work the same regardless.
    A honed fit tends to last longer than a reamed fit, due to no chatter. This happens with reamers especially adjustable ones.
    alanp561 and quickrack-alan like this.
  3. quickrack-alan
    quickrack-alan
    from Ireland
    I thought of that.
    They all use metric tooling.
    The pins are imperial.
  4. Lepus
    Lepus
    Alan, with that type of hone, the mandrels have stones that move in and out. If they have a metric size that's a little smaller than your kingpin size, they should be able to hone your bushings
    quickrack-alan likes this.
  5. Wrench97
    Wrench97
    .814"(20.6756 mm) is the size most use for the bushing ID, the pins are 13/16" (.8125) is the OD of the pin.
    So a adjustable reamer/hone that will do between 20mm and 21mm will work.
  6. blue 49
    blue 49
    from Iowa
    TagMan likes this.
  7. quickrack-alan
    quickrack-alan
    from Ireland
  8. Wrench97
    Wrench97
    I think you would want "F".
