This is a project to be assembled-about 95% complete. Small rust in Cowl panel, other rust has been repaired or replaced. Door and windshield have been replaced. 59AB Flathead. Rebuilt before I purchased. Has early Navarro 3 x 2 manifold, 3 - 97's Carbs - rebuilt by Uncle Max of the HAMB. Rebuilt fuel pump, Edmunds alum heads. Ferrari fuel filter with a adjustable pressure regulator. C4 Trans w/adaptor, Mustang floor shifter. Open drive differential adaptor, 1930 A Spring on top of rear axel. New Speedway front suspension. 4 wheel hydraulic brakes, stock A Frame, modified by moving front, cross member 2 inches forward, rear cross member Zed about 4 inches, F -1 steering box-modified with adaptor. Radiator with thermal static control, license and titled in Arizona - MUCH MORE! SPEEDWAY PARTS NEW # 916-39516 Front Suspension # 916-33006 Front U Bolt Kit # 916-3197 Brake Pedal Mount # 910-11005 Air Filter x 3 # 560-62713 Carb Progressive Linkage # 910-13601 Headers # 910-23101 Transmission Cooler
