History ***RARE Flathead Intakes, Lets see them!***
Discussion in 'The Hokey Ass Message Board' started by mike hamel, Feb 13, 2010.
  1. ChuckleHead_Al
    ChuckleHead_Al
    Here's all I have a Edelbrock tall regular 2x2
    Humm, it won't let me post the picture?
    Sent from my EVO using H.A.M.B. mobile app
  2. any more out there?
  3. fritzz
    fritzz
    from canada
    just picked this one up,hexagon tool co.[​IMG]
  4. etwheels
    etwheels
    from ca.
    I have several of these flat head manifolds for Scot blowers and I have the tooling to make more if needed. These could be adapted to other blowers also.
    scott
    ET Mags
    LOU WELLS likes this.
  5. realsteel1934
    realsteel1934
    from usa
    Mike -- this post is one I placed question to you back on # 50 about old speed shop from the 60s in LV.No one has chimed in yet with any details on that colection?
    Some body has to have some memory of that.I am still looking for anymore information I can find.Kevin
  6. Alaska Jim
    Alaska Jim
    how about these anyone seen another?
  7. titus
    titus
    seen a few of them for sale here and there, deffinately not a common one.
  8. Alaska Jim
    Alaska Jim
    titus, Thank you for your reply, I appreciate it.----Jim
  9. RichFox
    RichFox
    As seen on the Landspeed racing site. Not vintage. But pretty rare. An excellent example of Hot Rodding. If you want one. Put the catalog down. Build it.
  10. blindowl
    blindowl
    from MASS
    Just picked up this one
    LOU WELLS and Asphalt Demon like this.
  11. mike hamel
    mike hamel
    Has anybody ever seen this intake before? It had no names on it but it is two pieces. The two carb intake upper portion is removable and the only thing I could think of is to bolt 4 barrel intake onto it? I don't know. What do you guys think?
  12. quickchangeV8
    quickchangeV8
    The intake manifold you have is an Anderson. Anderson Industries from Indiana made these intake manifolds with a removable top piece ( you have the 2X2 one) so you could change the tops without having to unbolt the intake manifold from the engine. In addition to the 2x2 top there was a 3x2 top and a 4 barrel top. I believe the intake bottom piece and the 3 top pieces were sold as a set.
    Carter and LOU WELLS like this.
  13. Here's an old home made triple that I have hanging in my shed, it was single carb modified to start with over 40 years ago and was supposedly a good manifold when it was in use? ImageUploadedByH.A.M.B.1424673030.047574.jpg
    LOU WELLS and Jet96 like this.
  14. maneri
    maneri
    from ohio
    got a sandicie 2 x 2 v60 with carbs-- need info on it
  15. big duece
    big duece
    from kansas
    Well deserved bump; does anyone know if the Edelbrock 4x2 intake carb mounting surfaces are parallel to the block surface, or are the angle milled 3 degrees? Can someone post a pic of this intake with a straight edge on the carb mounting surfaces to see if they are step milled?
  16. titus
    titus
    if it was auto use it was flat, i had a marine one where they were angled, i dont have a pic with a strait edge tho.
  17. manyolcars
    manyolcars
    What can you tell me about the Offenhauser at the bottom of the picture? offenhauserintake.jpg
  18. bowie
    bowie
    It's made to be used with a head mounted , offset generator bracket; for one thing.
  19. Mozen
    Mozen
    I have this which has sharp on it but I could not find any other similar ones online. Any ideas fellows? It came with a pair of 50s v8s I picked up. Really want to know more about it tho please!!!
  20. drtrcrV-8
    drtrcrV-8
    My old 276 Merc sprinter used an Edelbrock 'Super-Dual' with 97s on methanol : no stumbles or flat spots from off idle to wide open.
  21. CadMad
    CadMad
    Here is my Frank Burrell intake for my 41 flathead Caddy engine. It's a new casting off the original molds. rps20150713_150039.jpg rps20150609_163754.jpg
    29bowtie, LOU WELLS and Jet96 like this.
  22. Turnaround
    Turnaround
    I would like more info on the 41 Caddy 2 x 2, Frank Burrell intake. I have a couple 48 flathead Cad engines, and I could get real interested in these manifolds.
  23. Ebert
    Ebert
    Has anyone heard of a two pot intake called a "AA Custom?" Thanks
  24. A few we snatched up over the years...Sharp 3 and 4 pot, Lightning 4, Freiman, Weiand, Almquist, Roof, Edelbrock Super, Navarro Racing Model, D&S, Fento, Cyclone, Hexagon, Offy, Grancor, Speed Gems.... 20150926_175513.jpg 20150926_175513.jpg
    kidcampbell71 and LOU WELLS like this.
  25. LOU WELLS
    LOU WELLS
    from IDAHO
    THIS TATTERSFIELD FITS A 1937-54 DODGE/PLYMOUTH SMALL FLATHEAD SIX (MODEL # 1870). TATTERSFIELD 2 003.JPG
    ENABLERS CC
    kidcampbell71, Jet96 and 302GMC like this.
  26. LOU WELLS
    LOU WELLS
    from IDAHO
    HOLLYWOOD Direct port 4X2 with 97s................................................ HOLLYWOOD 2015 013.JPG
  27. titus
    titus
    this is a neat thread, figured id bump it back up, i ended up with a Roof intake, and heads
    late edelbrock regular
    and i ended up with a cut up eddie meyer water heated top section that had the flanges cut off so i found a stock 33 intake and cut the carb m0unting flange off and sent ti to a buddy in Tx to welded it up, heres a pic of it not welded, i find a pic of it finished, kinda a jack henry type intake downsized_0507151349.jpg
  28. choppedtudor
    choppedtudor
    Here's a mystery, I just bought this aluminum intake dated 1947 with a VERY prominent "Circle-S" logo cast on the top. IF it's what I think it is...it could be very rare indeed.... intake1.jpg intake2.jpg
  29. titus
    titus
