Features RARE flathead heads Let´s see some
Discussion in 'Traditional Hot Rods' started by Dusters swe, Feb 10, 2010.
  1. Full Edmunds dressed 60 & a Simca Vedette 60
    Squablow and Asphalt Demon like this.
  2. 99BB0840-EEC3-4A01-87DE-C1CFD88E23BC.jpeg How about this conversion on an English Ford 10hp flathead 51A7D827-C23C-4C24-838F-DEA5F6BCAE8B.jpeg 51A7D827-C23C-4C24-838F-DEA5F6BCAE8B.jpeg
  3. 93BC8579-5AA1-41FB-9B49-26B84E89451B.jpeg 543C1D90-D6D5-4092-A592-59660E888EFD.jpeg FC57AA20-D5C0-4762-B227-AC6051528A62.jpeg But wait there’s more
  4. The above cam pic is Not an L100 but a hand made cam that came out of an engine in New Zealand no known info on it
    Kiwi 4d, 97 and 29bowtie like this.
  5. 5FC139C0-64D4-4409-8588-F04658F6593C.jpeg 5D05A24D-BCB4-412A-834E-006819AD9AFE.jpeg A7292F27-4E88-481A-8E25-472766CCF6E4.jpeg Different
    NOS on the Parker heads
  6. 75E3F7AB-73B5-41AC-8115-16F82B0C45CA.jpeg 1ECA8F6C-8E10-4354-B0B8-AF7C3E406342.jpeg 06CB8C2A-7CF6-442E-B01D-13832AD4F918.jpeg This shit seems piled every where
    I know I have a bad sickness
    kadillackid, 97, 29bowtie and 5 others like this.
  7. joe1932
    joe1932
    from NY
  8. V860too
    V860too
  9. V860too
    V860too
    I know where that 60 is now.
    Will soon be replaced with a BIGGER BADDER 60
  10. V860too
    V860too
    Unless you have a TIME Machine, Vic Sr passed away in 1962...
    So hiw could he have built a 60 using modern AN fittings????
    Why must people LIE to feel important?
  11. Joez
    Joez
    What a sleaseball scumbag piece of shit. Guess he had a SOB story to buyer he needed money for bail, to get Mom out of jail too!. Wow.
  12. Joez
    Joez
    All these are beautiful! This site killing me time wise so much to look at and not enough time to look feel like "Crazy Eddie" going Insane.
  13. Idlewild
    Idlewild
    from Denver, CO
    KiWinUS, cadillacoffin and Squablow like this.
  14. dmdeaton
    dmdeaton
    I have a older set of Offy's with the shallow tapped plug holes. What is the proper plug depth on a aftermarket head? H10C's screwed into the head and the electrode seems to me a little short in the hole. Reason for asking is I am about to Timesert all 8 holes as a couple have older helicoil repairs. I will take a pic of the heads and post in a few.
  15. I haven't followed this entire thread but these Federal Mogul's are fairly rare.....
    Burtzz and kidcampbell71 like this.
  16. ETriggs
    ETriggs
    from Alabama
    My Fenton heads. Not many of these around anymore I believe.
    97
    Ted Thompson had something similar , he thought it was either a Ron Hogan or Mundell and Slaughter experimental cam. I saw it in the 70s at his place in West Auckland. I know someone who got a load of his stuff after he passed, I will ask if that camshaft was in the pile. It had ES 2 or FS 2 or something similar stamped in the timing gear end of it. ... and had the fuel pump lobe ground off. Jeez the 70s feel like a long time ago.
    panhead_pete and KiWinUS like this.
  18. Oppy12345
    Oppy12345
    Do you still have the thickstun head covers and would you be willing to sell them?
    Regards,
    Reece
  19. seb fontana
    seb fontana
    from ct
    Looks like a set of Schram air compressor heads on a Ford v8; 4cyl compressor and 4cyl engine. Schram used many different engines up through the years as late as 351w Ford v8..
  20. Boxcar's 1928
    Boxcar's 1928
    Just picked up these heads "CUSTOM" for my Coupe's 8ba. Couldn't find any references/images on them. Thoughts?
    Squablow likes this.
  21. mgtstumpy
    mgtstumpy
    Automotive History The Small Ford Flathead V8 (V8-60), Part Three – The Simca Years.png
    Simca Vedette (v8 60)
    Arkus-Duntov (Ar-Dun) conversions also addressed another of the Ford V8’s issues by significantly increasing its horsepower. In the end, few if any trucks received them: they were expensive and allegedly required a bit of expert tinkering to work properly. Most Arduns ended up on hot rods and racers with Ford 3.6 litre V8s. Ardun also designed and made a few kits for the V8-60, some of which were exported to France for the Ford Vedette.
    loudbang and Burtzz like this.
  22. Mark Merritt
    Mark Merritt
    These very rare Stephens Valve in In Head Hemi Heads are on a club member's car here in Colorado. Only three sets known to exist. Pictures taken at our All Ford Day show last month.
    KiWinUS, 97, loudbang and 3 others like this.
  23. tubman
    tubman
    Now, you have my attention! From the illustration you posted, it looks like these were intended to be used with a standard Ford 2 barrel and FOUR Winfield carburetors.:eek:
    Look to be racing units to me!.
  24. RobC
    RobC
    from Australia
    No, look closer, the Ford 2 bbl is bolted to an adaptor that bolts to the 4 bolt flanges.
  25. tubman
    tubman
    I see that in the picture of the engine installed in the car. That appears to be the way the guy was able to "jury-rig" a carburetion setup to be able to run it. The picture from the brochure seems to show exactly what I stated. It doesn't make sense that they would make a manifold for their engine that allowed one one Ford carburetor to be bolted directly on the engine but required adapters for the other two.
    If you have ever tried to find 4 matched Winfield carburetors you would understand why he did what he did.
  26. The illustration shows the carburetor adapter in the forward position. It omits them from the rear two for illustrative purposes. The manifolds likely weren't intended to use the Winfield carburetors.
    The adapter allows the same manifold "log" to be used on each side and accounts for the fore/aft offset present due to the cylinder head positions and block deck heights. The original ARDUN intake setup utilizes a similar sort of multi-piece design.
  27. tubman
    tubman
    After considering your avatar, I will defer to your judgement.
    I was just spitballin' anyway.
