Happy to combine shipping. Money Order or cashiers check is fine. Also paypal as a gift, or add 3% for fees. $25. 17" USA made Elec fan. Works very well, but I'm switching to mechnical. Also included is 170 degree Perma-cool thermal fan switch 19003. I used it for about 50 miles before switching to mechanical fan. $5. Sunpro Oil pressure gauge and a bunch of gauge stuff: single gauge panel, 3 gauge panel, Sunpro temp gauge w/ capillary tube cut off but can be repaired with new sender, and variety of fittings, parts and bulbs. $20+10 shipped. Brand new, light blue aviation style lap belts. Aluminum buckles, quick disconnection latches on ends. $10 pickup, or $16 shipped. Standard Speedway clevis. 5/8" right hand threads and 3/8" holes. Includes jam nuts. These are $7 ea. from Speedway plus the jam nuts. $30. leftover speedway rear Hairpin. Tubing is threaded for 5/8" fine at all three ends. I used the other one to make a triangulated top link for my suspension. Includes the clevises. $20. Used 21" drag link or tie rod. Has left and right hand threaded ends to accept tie rod ends or heim joints. $14 or 30 shipped. Original early ford radius rod forgings (they are later than '33, but that's all i know off top of my head. $80 Ford Radius rods. Think they are late 32-34, but I don't know. Very good shape, minimal if any pitting. Just spray painted black. Both ends are uncut. 66.5" long end to end. $10 pickup, 26 shipped. Bracket to mount early Mustang steering box on bottom side of Hotrod frame. Perfect if you are running four link. It's a bit crude, but very stout and a few minutes with a grinder and flap disk could clean it up nicely. Made to bolt on to frame, but can be welded. $30 pickup, $60 shipped. Oval tube Transmission cross member w/ bolt on ends and heavy brackets. It was holding a Cadillac hydromatic, but it's pretty much universal.I think the center piece alone is typically $80 online. $5 pickup, 16 shipped. Remnants of original Model A headlight/fender brackets. Perfect start for headlight or shock mounts. Shipping only if someone can use it. Top part of f1 steering column w/ turn signal stuff inside, spring, bushing, etc. Tubing is 1.5"OD. use it to make a custom column or restore. $7 or 11 shipped. New banjo fitting for multi carb setups of Holley 94 or Stromberg carbs. for 5/16" fuel line. New is like $16 plus shipping. $15+6 shipped. New compact brass proportioning valve. Retails for 34.99 from Speedway. $20+11 shipped. Decided to stick w/ my points and coil. New in boxAccell chrome coil (8140C). Both have been out of package but never installed. Also includes a used resistor.
