Hot Rods Rake problem's
Discussion in 'The Hokey Ass Message Board' started by 19Eddy30, May 22, 2016.
  1. 19Eddy30
    19Eddy30
    from VA
    Has anyone else experienced there gear lube oil being transferred from the Rear ,threw torque tube to the transmission , over filling it ?
    32 Ford rear to 39 train's .
    4 inch Rake , measurement taken from the ground to frame .
  2. I bought a kit from a shop in Texas (can't remember his name). Consists of a flange that holds a seal. Goes in between torque tube and diff. Works awesome. I suppose a baffle would work too. But I like having it sealed up. Works nice.
  3. Mr48chev
  4. Bruce's hot rod shop was the place I think. His was reasonable price wise. It gets bolted in at the flange with the six bolts.
    Seabright has a little different style. Both do the same job but that one was more expensive.
  5. I think it was Bruce's rod shop that sold the seal kit.
  6. 19Eddy30
    19Eddy30
    from VA
    Thank for fast Reply's,
    So it's a common problem,
    I was thinking on Runing a DOT air brake line From fill hole @ train's to fill hole @ rear.
    3/8 or 7/16 line
  7. Well that's a creative solution. In my case it just leaked at the trans.
    You could try the baffle. I liked the seal better.
  8. 19Eddy30
    19Eddy30
    from VA
    Yes , I will look for seal ,
    D.O.T. Nylon Push lock for air brakes
    It looks to pushes less then 1/2 a quart with in 2,000 miles ,
    When I purchased the car it was @ stock ride Height.
    I noticed when I did my first service, that train's was over filled,( did not drain because of a little leakage)
    Rear was low , topped of rear , Now Secound service rear low with no leaks , figured out where it whent , so I removed extra from train's,
    Will test drive and see how much is lost in rear , every 50 -100 miles ,
  9. WiredSpider
    WiredSpider
    Bruces Rod shop sells the seal kit
    It,s about $100
  10. fatkoop
    fatkoop
    Here's the drill; drain off transmission, re-fill rear. Do so about twice during the summer, depending how much you drive and how steep the rake. What was the problem again?
  11. thommoina33
    thommoina33
    Alliance Member
    from australia
    Bruce's hot rod shop, hot rod pro on hamb.
    Quality part, been to slack to fit it up.
  12. Park on an uphill grade for a while.
    blowby likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    300 miles a week!
