Rajah plugwire ends. Who sells them??
Discussion in 'The Hokey Ass Message Board' started by AV8-Rider, Jan 11, 2005.
  1. AV8-Rider
    AV8-Rider
    I ned a set of 90 degreeees for my Flattie.
    Who sells these small gizmos??
    Paul
  2. The37Kid
    The37Kid
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    John Brilman supply.
    around 1.30 pc. and will have it to you in two days.
    Give me a yell if you can't figure out how to attach them.
    [​IMG] [​IMG] [​IMG]
    Don't ask me how I know you may have some trouble.
    Brilman parts
  4. AV8-Rider
    AV8-Rider
    Hey
    Thanks guys. Good tips. I also need to buy some old-loking wire.
    I'll get back to you on the support thing if I don't get it Petejoe. [​IMG]
    Paul
  5. Bruce Lancaster
    Bruce Lancaster
    Just hop in your time machine and pick up the Rajah pliers at Moon Equipment--they strip the wire to the right depth and crimp the non-screw on terminals too. No problem.
  6. Hot Rod and Custom Supply in Florida.
  7. Stovebolt
    Stovebolt
    Anyone got a picture of these plug ends. I've read about them but never seen them.
    What, besides their vintage, makes them so special?
  8. tommy
    tommy
    [ QUOTE ]
    [/ QUOTE ]
    They have a positive snap on lock that is much better than the brass wrap around fitting that came with the universal wire sets.
    They have a special place in my heart. When I was 18 with my first car I wanted to soup it up. Sound familliar? The cheapest and therefore the first hop up trick was to install Packard 440 stranded copper wires with Rajah clips. My first hot rod improvement. I'm sure the new technology big wires are more efficient but they aren't as romantic. [​IMG]
    Check them out here.
    rajah terminals
    The ss-sos and the as-sos are the ones I remember the most.
  9. Fifty5C-Gas
    Fifty5C-Gas
  10. Bruce Lancaster
    Bruce Lancaster
    In Tommy's link, AS-SOS and SS-SOS were the ones that useta be mandatory equipment for detailed engines, always with Packard 440 solid core wire. Other variants of the design have nickle plated sleeves or crimp-on installation with the same plug end clip, but I've never seen anyone using them.
    The sleeved models are permanent possessions which can be removed and screwed onto new wire when needed.
    The special Rajah pliers neatly snip&strip your wire to fit and also crimp the other kinds of Rajahs.
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    [ QUOTE ]
    [/ QUOTE ]
    The crimpers seem like a good idea, but the style I had did not have the provisions for a collar to crimp.
    The collar material was made too thick and would probably crack.I think Bruce may be referring to a type that has a softer collar.
    These are the types I used.
    The wire installs this way.
    Strip the plug wire end leaving about 1/2" of the core sticking out. Slide the wire into the collar inserting the core into the hole in the collar. Simply screw on the plug connector end. This end has a pointed area that traps the wire core in place and holds the wire onto the terminal.
  12. blueskies
    blueskies
    from Idaho
    I bought mine from Brillman too. I bought the clear red wire from Speedway or Hot Rod and Custom Supply, can't remember now...
    www.brillman.com
    Pete
  13. Bruce Lancaster
    Bruce Lancaster
    Do the currently available ones have the Rajah lettering on them? They look like they don't from the rather poor pics I get on my computer.
    The crimping tool is for the crimp-on style Rajah that doesn't have the bakelite or nickle screw-on sleeve.
  14. Stovebolt
    Stovebolt
    Thanks for all the info guys.
    There's a whole bunch of info on the HAMB that makes it so much of a joy to be here.
    Thanks Ryan for bringing it all together.
