I have 1947 ford radius rod front end that has been welded to the axel.and i need to remove the stock shock mounts.so i guess a cut wheel would be best.?.then i can split them. Sent from my SM-G928V using The H.A.M.B. mobile app
A better explanation and maybe pictures of what you are dealing with would probably result in an appropriate response. Cut off wheels can take care of problems; but can also be the cause of bigger ones.
You may find that a dremel tool, albeit slower, may be a tad more surgical approach. I had an axle with 37-40 spindles that were welded on for a trailer, in order to save them a bit of time was required. But they can be saved. Sent from my iPhone using H.A.M.B.
