Radiator pressure question?
Discussion in 'The Hokey Ass Message Board' started by ZZ-IRON, Mar 22, 2012.
  1. ZZ-IRON
    ZZ-IRON
    from Minnesota
    just picked up a new aluminum Griffin radiator for a 57 T Bird like near free
    it's going in my 50 Olds which is getting a rebuilt 55 Olds 324
    the cubic inches multiplied per square inches of the core works
    the installation fit is close
    Pressure Question -
    the Griffin can take a 16 or 17 pound cap can the 55 Olds 324 take that pressure
    or is a 12 to 14 pounds a better option
    Thanks for any input
  2. Gary in da UP
    Gary in da UP
    More is not better. If that rad can't keep it running at less than 190 degrees unpressurized in temperate minnysoda, Something is wrong. Start with an 8 lb cap. I fix and recore a lot of rads. Too much pressure makes them bulge and split, failure rates go up.
  3. Rex_A_Lott
    Rex_A_Lott
    Dont worry about the radiator, worry about your heater core, if you have one. Use the lower 7# or so as suggested.
  4. ZZ-IRON
    ZZ-IRON
    from Minnesota
    7 or 8 pounds now that rings a bell yeah that's sounds like the answer
    Thanks
