I am putting a 283in my 32 roadster with a walker radiator and wondering if anyone out there knows of a pre-formed radiator hose that would work on the lower hose from the water pump to the radiator. Someone has to have gone through and found one and I would appreciate the help. Thanks.
The Gates buyers guide catalog has come in handy for me a few times to find hoses. Gates has their catalogs available online. http://www.gates.com/catalogs/file_display.cfm?file=GatesIDGuideSections.zip&thisPath=gates\catalogs Once you download them, the one you want to look at is the "Product Line-Hose" it has pictures of their hoses in order of dimension(diameter/length) Cesar
Lower- I used a Gates 20242 & don't recall having to trim it. It lacks an internal spring so I bought a cheapo hose & used the spring from it so it wouldn't collapse. Upper I used a 20607 & cut to fit. Upper depends on your water neck though. The 20242 is the same one So-Cal sells for double the price- same exact hose, same number.
This hose is great. Its made by Gates and The best part is you can Flip it around both ways to see which fits best.
