rack and pinion identifier
Discussion in 'Questions & Suggestions' started by ralph_gangler, Jan 25, 2018.
  1. ralph_gangler
    ralph_gangler
    need this rack identified off of a 1949 Hudson. Any help appreciated.[​IMG]
    Sent from my SM-N950U using Tapatalk
  2. Some better pics and more info would help. Like what suspension, measurements that kind of stuff
    At first glance it's similar to dodge omni, at least the mounting any way. and quite popular in our hobby
    You would get better response on the main board
  3. v8deuce
    v8deuce
    74-78 mustang check weather hose fittings are flare or o-ring, flare is the earlier ones
  4. v8deuce
    v8deuce
    I may b wrong on that last comment Im sure the m2 rack has a solid p/side mount but someone could have machined it off
  5. ralph_gangler
    ralph_gangler
    After a little more research found this part 8011820-01 from Summit or Jegs. I want to know if the tie rods are serviceable or what the rack possibly came off of. This pic shows a Malibu rack beside it. almost a match. tie rods are too long.[​IMG]
  6. No way that's mustang rack . It's backwards and the mounts are wrong.
  7. No way is that a match.
    Yes tie rods are changeable.
    Moog probably has no less than 50 different tie rods that will go on that rack out of 1200 or so part numbers.
  8. Here's a dodge omni,
    It's close but not
    Mustang 2 rack
  9. You can match up the tie rods by size in the moog book.
    Application is irrelevant then
  10. ralph_gangler
    ralph_gangler
    what year was that Dodge omni? Thanks for replies
