That is a bit close. You dont want to cook that piece!! Big $$$ if you got to replace it. Move the exhaust before you drive it. Todd
Been driving car at least once a week now...didnt realize it was that close Will take to muffler shop in morning
Get car back later this week.Went to have exhaust rerouted;after which, ended up putting the car in the shop for a tune-up,synchro those carbs...etc;when I get car back then I will finish OD project. THANX for all the feedback
Ok,got car back from shop.Installed dual point distributor,synchronized the carbs,installed the Beehive oil filter.Took over 2wks ;Could have done it all in one or two days.Another lesson learned,i guess.Anyways this wknd will test drive the OD setup.
I just put a 3 speed with r-10 in my car, read this thread to see wiring options. I had put the idea together to use a relay with switch power off the key instead of on a toggle switch and then to use the governor to switch the overdrive on with no other input. My idea was to have an automatic overdrive shift with little or no input by me, while using the pull cable to lock out the overdrive when not needed. After reading this im wondering if my idea will work? Also ive read you cant compression break with this trans nor can you leave it in gear to hold it on hills, this thread suggests otherwise.
Thanks for the clarification on that, my parking brake doesn't hold on the steeper hills and I compression brake a lot in town. What are your thoughts on my wiring idea, I saw someone else mentioned something similar but if i remember correctly it involved a toggle switch.
weather has been pretty bad lately.Might get out 2morrow&take car for a short drive.Just been busy with more important honey doos lately...
Drove the car today.It ran great!The OD seemed to work just fine.Only used it on the highway.THANKS everyone who showed an interest
I finally got around to hooking up my cable and wiring but nothing happened. When i pulled my cable it didnt freewheel, i could still compression brake. Im not sure if my solenoid is activating. any help would be great.
I hooked up my soleniod directly to a toggle switch and tested it, it is activating. tried activating overdrive and nothing happened, just read that the cable is supposed to be in for overdrive I have been pulling it. So the cable is supposed to be pushed in for overdrive, lever on trans pushed back towards output?
Ive tried overdrive with the cable in and out, neither way works. Also im not getting a freewheel either way, any ideas?
have you tried powering solenoid with cable in ,in second or third gear while driving its been awhile since i drove mine but i don't think it free wheels till its in o\d
I've tried with the cable in and out, powering the solenoid after moving the cable. I think I tried in second once but usually In third. I let off the gas and also tried pushing in the clutch
I tried the overdrive again today, still isn't shifting but when I got off the freeway it seemed locked up when trying to pull away from the light. It would roll slightly then stop like like tied to something. It would only move after disengaging the solenoid
