Has anyone used this regulator? http://www.quickfueltechnology.com/low-pressure-regulator.html Good? Bad? Other suggestions? Thanks, Ryland
Not sure about that one, but I have heard these are good. I just bought one off e-bay. They look kind of vintage . Bloodyjack used one on his T roadster too. Part No. FPR006. Regulator/Filter (85 mm transparent bowl). 6-8 mm tails. A mounting kit is supplied with the regulator. Brand new in its box Regularly seen in the motorsport field because of its ability to regulate and filter fuel without restriction. The Malpassi Filter King is a combination fuel filter and pressure regulator. They are low pressure units for carburetor applications and the output pressure can be adjusted in the range 1.5 to 5.0 P.S.I using turning the slotted adjuster located under the dome nut on the top of the unit. They are designed to be fitted in line between the fuel pump and the carburetor and are supplied with barbed fittings for use with push on hose. Specification: Pressure Range: 1.5 - 5.0 p.s.i Bowl Type: Glass Bowl Depth: 85mm Fittings: 6/8mm stepped tails Filter: Pleated paper replaceable element (part number RA002) Fuel Pressure Take Off: None
If you were talking about the one I bought. I got it for $38.33 US, shipping is costing me $15. Doesn't seem all that expensive to me.
X2--It can be a china clone of the Holley...But...The last Holley regulator I bought from Summit [higher pressure version, 4/9] took three tries to get a good one, first two were actually asembled wrong..So, you takes you chances..
i was told that the quick fuel guys used to work for holley, then when holly let them go they started quick fuel.
That is a good price. The one I saw was $75 without shipping. *edit* looking again I found one for around the price you posted. ** I think I'll order the quickfuel one, worst case I'll return it. Thanks, Ryland
Thanks for the replies! I Just ordered one, paid $30 shipped. I'll post what I think about it when I get it. Ryland
Its been awhile but just wanted to update this; I've had the regulator installed of awhile now and its doing great. Their tech support is very good as well. Ryland
