Hot Rods quick change rear
Discussion in 'The Hokey Ass Message Board' started by mikyboy, Dec 11, 2014.
  1. mikyboy
    mikyboy
    Do these tend to hop on full lock around corners?
  2. alchemy
    alchemy
    A quickchange doesn't have to have a locked differential.
  3. Mike VV
    Mike VV
    from SoCal
    Correct, just depends on the "differential" (carrier) you use.
    Yes...a spool will spin/rattle/hop the inside tire.
    An open or normal "posi" style unit will not.
    I have the gear driven, Dana Trutrac unit in mine with zero problems.
    Many carriers to choose from.
    Mike
  4. Pewsplace
    Pewsplace
    Hop is not good but you can live with it. Changing to a differential will eliminate the hop.
