Hot Rods questions about Ford intake sb
Discussion in 'The Hokey Ass Message Board' started by brownieandthemerc, Jan 31, 2015.
  1. brownieandthemerc
    brownieandthemerc
    from ontario
    hey guys
    I fouxnd a 1968 4 bl intake for my 1985 (both 302) However my heads have an open coolant port to the manifold which line up in the 2 bl 1985 intake. The 1968 intake has no ports for coolant to flow through and the manifold is flat on top in that area, so the coolant in the heads at the back ports has nowhere to go through the intake. Am I going to have heating problems by not hacing the coolant flow from the rear port of the heads?
  2. gallagher
    gallagher
    from califorina
    I have used early intakes on a late 302s never had a problem
    Sent from my DROID device using the TJJ mobile app
  3. Almost all aftermarket intakes dont have that crossover either.
  4. brownieandthemerc
    brownieandthemerc
    from ontario
    gg
  5. brownieandthemerc
    brownieandthemerc
    from ontario
    great thanks for thenquick reply
    chris
  6. Engine man
    Engine man
    from Wisconsin
    I think the reason they added that crossover on newer engines was to be able to put a port to run coolant to the heater core. The coolant is pumped into the block, flows into the heads and comes out of the front ports on the heads into the intake to the thermostat. The heads have ports in both ends because they can be used on either side so the back would be the front. All the rear crossover would do is connect the 2 heads.
  7. BamaMav
    BamaMav
    from Berry, AL
    I put a early Offy intake on a 85 5.0, never had any problems with overheating or with the cabin heater functioning right either. You should be fine unless something freaky jumps up.
  8. brownieandthemerc
    brownieandthemerc
    from ontario
    Ok great thanks
  9. brownieandthemerc
    brownieandthemerc
    from ontario
