Hot Rods question on a '33 ford rear end.
Discussion in 'The Hokey Ass Message Board' started by Vernon2, Oct 22, 2021.
  1. Vernon2
    Vernon2
    Can anyone tell me what the '33 ford rear end ratio is. Is it different from the Model a?
  2. alchemy
    alchemy
    They each were available with a variety of ratios.
  3. Deuce Lover
    Deuce Lover
    Yes different than a Model A. Most likely 4.11. The only other ratio available in '33 & '34 is 3.54.Scrape under the banjo web and numbers should appear if it hasn't been altered.
  4. 42merc
    42merc
    The common '33-'34 ratio is 4:11 to 1.
  5. Vernon2
    Vernon2
    Thank you all for reply.
  6. samthsham
    samthsham
    alchemy is right again the 4 bangers came with 4:33 the v/8 had 4:11 3:78 3:54
