Hot Rods Question for the upholstery experts
Discussion in 'The Hokey Ass Message Board' started by 41woodie, May 4, 2021.
  1. 41woodie
    41woodie
    I'm using split hidem to trim the front and rear edge of the vinyl roof on my 41 ford woodie. When driving in the tacks I keep catching the edge of the two "flaps" that come together to hide the fasteners. Is there a special tool or technique that holds the "flaps" apart while driving the tack so they don't become trapped under the head of the tack.
    If I had three hands it would be pretty easy but sadly.....
  2. BJR
    BJR
    Why not use a small punch and hammer to drive the tacks in?
    Hnstray and Fortunateson like this.
  3. alchemy
    alchemy
    How about whittle a little piece of plastic to hold the flaps apart so you can tack between them?
    Fortunateson likes this.
  4. continentaljohn
    continentaljohn
    It’s a little metal part that goes into a point and is attached with a screw in the center. 1BB00B08-0E15-4C05-AB46-7044A3C97A63.jpeg
  5. stanlow69
    stanlow69
    That goes on the ends. Do you have an air stapler. Use a wide blade screw driver. Or your finger.
  6. Mimilan
    Mimilan
    Use an electric stapler with the "nozzle" ,and slide it along inside the hidem as you go.
    Duofast is the best.
    You can also use a small windshield rubber "filler tool" but they are a PITA.
    Buy the stapler and do the job. [as a bonus you can keep the stapler]
  7. greybeard360
    greybeard360
    Air stapler and stainless staples. Regular staples will rust and leave stains.
    loudbang and Chris Casny like this.
  8. 41woodie
    41woodie
    Don't have an air stapler but that sounds like a good answer. The original method seems to be small tacks rather than staples but I'm not interested in original I'm interested in a secure attachment. The problem with the "finger", screwdriver, punch etc. is a lack of extra hands. Hammer in one hand, nail between thumb and finger of second hand leaves me short an extra hand to hold the "flaps" out of the way
  9. Reminds me of a couple of dates I had years back.!!!
  10. stanlow69
    stanlow69
    Use a magnetic tipped tack hammer. A little easier. But stainless steel staples is the way to go. Their are 3 types of hydem. Marine, standard and convertible top quality. Marine, the staples like to blow thru the vinyl. It tears easily. The other two are a bit more durable. Just used some hydem last week.
  11. 41woodie
    41woodie
    . I'll bet the hammer and tacks were a surprise for her
    loudbang and Guy Patterson like this.
  12. Mimilan
    Mimilan
    In most households , he stays home getting "hammered". While she "tacks" it on the credit card
    No surprise at all :p
    Use 1/2" crown staples.
    If you use 3/16" carpet staples it perforates the vinyl making it rip along the staple line.
    loudbang and Hnstray like this.
  13. patsurf
    patsurf
  14. stanlow69
    stanlow69
    What`s a carpet staple.
  15. Mimilan
    Mimilan
  16. 32 hudson
    32 hudson
    Where can I get the Hidem ?
  17. Happydaze
    Happydaze
    Search Hidem Banding.
    Chris
  18. Mimilan
    Mimilan
    When you trim your car in cool "cheetah skin" fabric you have to make your own.:D
    reagen likes this.
