I just put an S-10 rear end in my 51 Ford sedan. I have a 302 with a C-4 and the rear end was the stock one before the swap. So the driveline is set up for the stock rear. My question is: Is there a u-joint that would adapt the S-10 rear end to the driveline that is set up for the stock rear?
TMoney, check with your parts store, I have purchased u joints with different size caps they may have what you need.
Last resort I'd try Pyle bros in Baytown, tx. I've called for tech advice and they were helpfull. Around here they are gurus Posted using the Full Custom H.A.M.B. App!
NAPA has always had the U-joints in stock I needed, I just got one from them for a Chevy driveshaft to 8.8 Ford rear-end pinion flange. They should be able to get what you need.
Don't be surprised if you have to have a driveshaft built or replace it; the '49-56 Fords used a oddball rear u-joint and I was unable to find anything that would work when I did a 351W/FMX swap into the '56 sedan I owned at the time...
I think the oddball part is on the rear end side, not the driveline side of that u-joint. The cups that go in the driveline are similar to most. Posted using the Full Custom H.A.M.B. App!
Conversion U-joints are available,call these guys for info.My '54 Ford has a 302 & AOD by using a 1986 Crown Vic driveshaft which has the correct yoke for AOD or C4 and this:http://www.drivetrainamerica.com/p-6076-neapco-2-0291-2c1310-conversion-u-joint.aspx It is a bolt in swap that a fair amount of Ford Group members have done in 1954-56 Fords.
My 1953 Ford Mainliner 6 cyl has a "mechanics" style U joint. They were commonly used in International trucks. It has a " tooth" on each cap. The diff yoke has a little recess for each "tooth". We IHC guys are used to this weirdness.
If the conversion joint doesn't work out, a driveshaft shop should be able to replace the yoke on your driveshaft so you can use a stock s-10 u-joint Sent from my Verizon 4G LTE smartphone
There isn't a conversion u-joint. But I did take it to the driveline shop and he changed the yoke. Easy enough.
I'm using an s-10 driveshaft on a Ford 8-inch. I was able to buy the universal joint for each then just swap the bearing cups. I ended up with a spare too.
Fortunately I have a fantastic driveline shop locally! Every time I do a rear axle, or engine swap they come up with the proper adapter U joints to make it work. And the best part is they sell them cheap, and install them! My last driveline swap cost me $43 for two adapter joints installed to put a TH400 style yoke on a TH350 style driveline, and then adapt the back from TH350 to Explorer flange U joint. Six States is great!
