Hot Rods question about a narrowed rear
Discussion in 'The Hokey Ass Message Board' started by 59 brook, Jul 7, 2014.
  1. 59 brook
    59 brook
    i have the oppurtunity to have the rear end in my car narrowed 1" on each side at no cost to me. I have the clearence needed inboard, and i would not have to move the control arms any.This would make it much easier to remove the wheels and the new rims are at least 1" wider then the original rims. Would there be any negative effects?
  2. tommy
    tommy
    The biggest negative affect would be the cost of having new axles made to fit the narrowed housing. You can't re-spline an axle shaft 1" so you will be forced to buy new axles$$$$
  3. if its free go for it ;)
  4. 59 brook
    59 brook
    even the axles would be free
  5. Mike VV
    Mike VV
    from SoCal
    Many axles have excess spline already cut into the shaft. If you get lucky, you may get away with utting off the excess 1".
    Hell if it's all free, and you;d like id done, there IS NO down side.
    At LEAST...buy the guy lunch...!
    Mike
  6. 19Fordy
    19Fordy
    You already know the answer is "YES."
