Technical Question about 1956 Olds rear end
Discussion in 'The Hokey Ass Message Board' started by willys36, Sep 20, 2021.
  1. My '56 Oldsmobile rear end has a leaking pinion seal. ebaY sellers and Summit all list the same seal for '50-'64 models. I know for a fact that the rears were significantly redesigned in '57 and most parts don't interchange between eras. The sellers list differential paper gaskets the same way so I ordered one and it was 1 1/2" too large in diameter for my earlier rear. Don't want to spend $35 on the wrong pinion seal!
  2. You can pop the seal out, take accurate outside/inside diameter and thickness measurements and find a match that way.
    Hnstray likes this.
  3. Yes, that's plan B. Am on vacation and wanted to order it so would be there when I get home if possible. Guess I could go to local auto parts store but lately have found they just carry parts for late model econo-cars.
  4. 34Phil
    34Phil
    -Brent- likes this.
  5. Thanx. Like you say, they only advertise the 9.3" , '57 up units. Will give them a call though, thanx.
  6. flatoz
    flatoz
    SFK 19438 - pinion seal
    is the part you want. 54-56 Olds
    you don't want gasket
    RDS6431- wrong gasket
    this is too big, but what alot of the big houses sell as fitting the Olds, ask how I know. And makes it worse when you pay to get 2 of these to Australia.
    The gasket you want is 10063E I think its a Best gasket. its for 53-56 Olds read ends
    46Chief and elgringo71 like this.
  7. studebakerjoe
    studebakerjoe
    My C/R book lists 19438 for 53-62 so I'd agree with flatoz
    302GMC and elgringo71 like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. 1934coupe
    1934coupe
    Willys36 I'll look it up tomorrow, it's my anniversary tonight and my wife might get mad.
    Pat
    elgringo71 likes this.
  10. I think I solved the problem. I made my own gasket w/ paper gasket material and I called https://fabcraftmetalworks.com/ recommended by 34Phil above and he hooked me up with the proper pinion seal which is leaking like a sieve after being in service for about 60 years.
  11. 1934coupe
    1934coupe
    Willys36 I did look it up and the results are;
    CR brand:
    53-56 #19438
    57-62 #19438 (the rear pinion bearing is different)
    National brand:
    47-52. #6244
    53-62. #6654N
    63-64. #8163N
    Pat
  12. vtx1800
    vtx1800
    Is it time for a sleeve too? It seems like all of the old stuff I work on has wear in the seal area.
  13. Will check that when I get the yoke out. I'm hoping it is just 60 year old rubber that's the problem.
  14. flatoz
    flatoz
    Speedi sleeve is
    Skf #99193
