Quarter Elliptical Front Ends-I need pictures!!!
Discussion in 'The Hokey Ass Message Board' started by 34dodgehemi, Jun 18, 2008.
  1. 34dodgehemi
    34dodgehemi
    I am thinking about using quarter ellipticals on my truck. If anyone has any pictures of some quarter elliptical set-ups, I'd love to see them.. thanks!
  2. Mr48chev
    This a little modified that I think is on Whidbey Island Wa
    I saw it at the Run to Roslyn three years ago
    It is a pretty straightforward and simple car.
  3. feerocknok
    feerocknok
    from Bend, OR
  4. Not here! Cool ride!
  5. feerocknok
    feerocknok
    from Bend, OR
    Worked for me now.
    Is there no need for a panhard/track bar in this set up?
  6. 34dodgehemi
    34dodgehemi
    Thanks for the pictures guys. I really like the set up on the yellow T..
  7. Relic Stew
    Relic Stew
    from Wisconsin
    Millers used a quarter elliptic 4-bar arrangement;
  8. woodyford
    woodyford
    from Sweden
  9. JOECOOL
    JOECOOL
    In my opinion the one in the first picture should not function very well. The radius rods locate the axle but the spring should be mounted on a shackel,instead it's mounted solid and have different points trying to all hold an a different arc means something will have to give [​IMG]
    I used a 57 chevy rear springs ,light long half on the lighter rear ,shorter stiffer half on the front,reinforced the bottom of the frame rail. two bolts through,upper link made out of tube,( if I did it again I would make them rubber bushed)
    No locator needed
    Best of luck
  10. Kirk Hanning
    Kirk Hanning
    Here are a couple pics of my front end set-up. Due to be put on the road within the next week or so.
  11. Joshua Shaw
    Joshua Shaw
    Here are some shots of the Chassis I built for the Dynamat roadster.. The Dynasport.
    The first ones suck, they were taken with a cell phone..
    That last shows a Big Clunky shock mount.. I DID NOT DO THIS.. DON"T do it this way..
    Do it the way I was gonna do it.. Run Speedway motors friction shocks on the inside of each rail in between the springs, out to the axle..
    This was Harry Miller's way of doing it..
    JD
  12. gearheadbill
    gearheadbill
    This is one we're currently doing.
  13. 2002p51
    2002p51
  14. It will work the same as a 4-bar.No problem.
    If you have hair pins or a 4-bar,AND 1/4 elliptic springs,
    then you will need shackles.
  15. JOECOOL
    JOECOOL
    Sorry i wasn't clear ,I meant the pic in the first post would not function right ,mine does very well.
  16. Here's a full cantilever for you I snapped at a show over here. Probably softer than quarter elliptics.
  17. Nice fab work! I agree on the shocks; too modern and the mounts detract from the clean flowing look.
  18. willowbilly3
    willowbilly3
    from Sturgis
    I have a 24 Cheby roadster buried out in my junk pile that has 1/4 elips on all 4 corners. They angled the springs outward 2-3 inches from the frame on that car. Any triangulation is good for lateral stability and strength, imo.
  19. Mattilac
    Mattilac
    I saw this on another thread. Just had to post it. :eek: :eek: :eek:
  20. here's mine
  21. alchemy
    alchemy
    I like how he used the coiled up brake line as helper springs on the pickup two pics above. (insert surprised look smiley here)
  22. Mattilac
    Mattilac
    Well, it's all about safety. Look at that caster angle!
