Q mini-tub a unabody
Discussion in 'The Hokey Ass Message Board' started by No_Respect, Aug 14, 2007.
  1. No_Respect
    No_Respect
    from So-Cal
    I have a 63 falcon That I would like to fit some meets 8-10 wide tires under her. how hard is it to mini tub a una body? I would like to do it for a resonable price any ideas
  2. Swifster
    Swifster
    You need to cut the inner wheel house away from the floor and the inner wheelhouse. The best way is to drill out the spot welds. Then trim the floor back as far as the inner wheelhouse will be. Then span the gap with similar guage sheetmetal spot welded to the inner and outer wheelhouses. Watch the space between the quarter and the frame. That's your maximum width unless do major work to the frame.
  3. No_Respect
    No_Respect
    from So-Cal
    i guess i was looking more into it than there is
  4. pimpin paint
    pimpin paint
    from so cal
    Hey,
    It's been a looong time since I was under an early Falcon, but I
    do recall that for an early unibody they were built like a brick shit
    house! Does the frame rail run right along the otherside of the inner-
    wheel house? If so, you'll have to rebuild that frame inboard and tie
    all of the rear floor, wheelhouses, stretcher panels into that design.
    If ya don't, you'll build a hinge into the rear of that vehicle, probably
    collapse the quarter panels outwards, and may even, depending on
    how many horses you're gonna run, spit the back window out.
