Technical Push Rod Length
Discussion in 'Traditional Hot Rods' started by dart4forte, Aug 9, 2021.
  1. dart4forte
    dart4forte
    from Mesa, AZ
    By chance is there any early Hemi owners that happen to know the Desoto 330 Hemi pushrod length?
  2. ras
    ras
    Pushrod_01.jpg Pushrod_00.jpg From a 1956 330ci, hope this helps.
    Rick
  3. dart4forte
    dart4forte
    from Mesa, AZ
    Looks 10 3/4”
    Elcohaulic and Deuces like this.
  4. Beanscoot
    Beanscoot
    Aren't the intake and exhaust pushrods different lengths?
    Deuces and Desoto291Hemi like this.
  5. dart4forte
    dart4forte
    from Mesa, AZ
    I thought they were all the same with non adjustable rockers
  6. Intake and exhaust will be two different lengths,,,,,be cautious of that .
    Tommy
  7. dart4forte
    dart4forte
    from Mesa, AZ
    So not same length. Inherent with all early hemis?
    Desoto291Hemi likes this.
  8. Deuces
    Deuces
    from Michigan
    A good pair of 12" calipers should get you very close.... I have the Mititoyo calipers... Very accurate!...
    LWEL9226 and Desoto291Hemi like this.
  9. The ones for my 426 are two lengths as well,,,,,,it all goes back to the rocker layout .
    The intake rockers rotate inboard,,,to push the valve down .
    The exhaust rotate outboard to push the valve .
    Since the exhaust rocker is almost twice as long ,,,,it requires a different angle of attack from the pushrod,,,,,so length is quite a bit different .
    Tommy
    Deuces likes this.
  10. dart4forte
    dart4forte
    from Mesa, AZ
    Good to know
    Deuces likes this.
  11. indyjps
    indyjps
    Pushrod length checker is $20-$30. Blocks get decked, Heads get milled. Buying pushrods twice sucks.
    LAROKE, Deuces and guitarguy like this.
  12. sdluck
    sdluck
    Cams are Reground,no one can give you the correct answer,measure for your self.
    Deuces likes this.
  13. dart4forte
    dart4forte
    from Mesa, AZ
    Fortunately I have the build sheet for this motor
    Deuces likes this.
  14. Bert Kollar
    Bert Kollar
    Exhaust are longer, high decks longer than low decks
    Deuces likes this.
  15. ras
    ras
    I apologize for the quick and misleading response last night. That’s what I get for trying to do one more thing before I go in for the night, I should know better. Every response after mine is accurate. The exhaust and intake pushrods are different lengths. And much more accurate measurements are needed to complete the build of a high end motor.
    Maybe I misread or misinterpreted your question but I took as a generic question. As in; I have these pushrods laying here but I don’t know if they are Desoto, Dodge, or are poly motor pushrods, about what length am I looking for. Or I’m headed to a swap meet but… Never would I assume someone would build the engine using the same tools as to frame their house.
    The pushrod pictured is an exhaust. Taken from a 1956, S-23, 330ci motor, if you had seen the rest of the motor you would be as confident as I that it had the original pushrods. It may have even had the original oil. If you want a rough measurement for the intake I can get you that this evening. If you are looking for a good set of stock pushrods, I suggest watching the Hot Heads Swap Meet site. As mentioned by many of the previous post, most people that put thousand’s into their build go with adjustable pushrods. That leaves a lot of stock sets being sold for around $20-$30 a set.
    Rick
    Deuces likes this.
  16. DDDenny
