I purchased an aftermarket turn signal stalk that is supposed to be clamped up near the steering wheel but when I put it on it just didn't fit well. I decided I needed to move it further down the column and go with a push-pull type setup. The lever is a 1/4" rod that runs down the steering column and attaches to the turn signal box. The rod pushes in for right and pulls out for the left side - off is still in the middle. The handle is a spoon gas pedal from a '30s truck. I also mounted the brake light switch to the housing that hits the brake pedal and the entire assembly slides on the column then attaches with a bolt & lock nut.
Ha, yeah I guess it is. It functions the same way when you are sitting in there, tips of the fingers on the paddle.
