Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. Mikel50
    Mikel50
    Passenger side filler panel went real smooth.
    This am
    Had to make a mount that attach to the body so I had a point to mount the filler panels.
    Bent up a piece of sheet metal for a mount
    Shrink and stretch to get it to contour the body line
    Drilled and Cleco’ed the filler to it.
    Now to make the mount for the drivers side and the two top filler pieces that will be removable.
    Coming along
    barrnone50, JOYFLEA, Ritzy1 and 10 others like this.
  2. mike bowling
    mike bowling
    Stogy, loudbang and Mikel50 like this.
  3. sloppy jalopies
    sloppy jalopies
    Wicked Good work... you are not allowed in my garage without a blindfold !
    Stogy, loudbang, brEad and 1 other person like this.
  4. Mikel50
    Mikel50
    Finished up the drivers side. Gonna go chill out for the afternoon w the kiddos. IMG_4427.JPG
    Still got a ways to go on the bulkhead but it was a productive weekend.
    Mtn Goat, JOYFLEA, chop job and 8 others like this.
  5. looks like the boat wheel was a big help....nice job, you deserve an afternoon off:D
  6. Mikel50
    Mikel50
    It definitely helped out.
  7. Mike Colemire
    Mike Colemire
    I put a wheel on mine, last night I ordered sprockets and chain to go with this garage door motor I have. Going to try and motorize it. Your work is amazing, metal work is over the top.
    loudbang, brEad and Robert J. Palmer like this.
  8. Aaron D.
    Aaron D.
    Nice metal fab Mike
  9. Mikel50
    Mikel50
    Thanks guys
  10. Mikel50
    Mikel50
    Finished up the fuel tank bulkhead over the week
    Added some flanges to rest my removable corner covers.
    This piece will attach to the top of front filler panel. It will be a rest for the corner cover also.
    Start of the layout on the two corner covers
    This is the pass finished panel.
    Drivers side is mirror image.
    Created a new cover for the fuel filler
    I'll finish trim and weld it to the top once it's time
    I needed to lower the grill shell and radiator to get the look and rake I needed for the hood. When I build one.
    So out come the cutoff and I sectioned the front cross member.
    Templates and cut some fillers for both sides.
    3/4" lower now. Also helps with lower radiator hose alignment to water pumps.
    2 for 1 kinda deal.
    Now I need to cut up my grill shell again unfortunately.
    Win some ya lose some I guess... that's tomorrow project.
    Get out and build something !!
  11. NashRodMan
    NashRodMan
    Incredible!
  12. sloppy jalopies
    sloppy jalopies
    good stuff...
    did you have to section the front crossmember because the aluminum radiator's lower tank is rectangular not a series of angles like the stocker... ?...
    are the radiator's lower mounts located in the same spot as the stocker's... ? …
    loudbang and Stogy like this.
  13. Mikel50
    Mikel50
    Yes to your first question of the shape of the radiator.
    I've never even seen a stock 28/29 radiator. So I have to assume the mounts are, They lined up on the crossmember just fine.
  14. Mikel50
    Mikel50
    Sectioned and remounted the grill shell ... that 3/4” in the crossmember was the perfect amount
    Temporary hood looks spot on.
    Get off the couch and in the garage,
    These cars won’t build themselves !
    JOYFLEA, brEad, patmanta and 2 others like this.
  15. mike bowling
    mike bowling
    IMG_0963.JPG t
    Takes a lot of tape to build a hot rod! Lol
    brEad, biggeorge, gonzo and 4 others like this.
  16. Tape hood looking good!
  17. mike bowling
    mike bowling
    Reporting live from Maynard Elks Club!
    MikeL50 was seen at a local swap buying parts for his : coupe, roadster, or sedan ? Pick one.
    I was talking to his friend Sean, topic was “ Why do we buy this stuff?” Answer was “Because it’s neat to look at!” I guess he has a point......
    (ATTACH=full]4231485[/ATTACH]
    biggeorge, brEad, greaser and 2 others like this.
  18. Mikel50
    Mikel50
    Picked up a few goodies ... Sedan is on hold at the moment. Wasn’t really the plan but I’m neck deep in the coupe at the moment.
    Making some changes before it’s time to enjoy it for the summer. Once it’s out of the shop, I’ll resume work on the sedan.
    Enjoy fellas [​IMG]
    This is my inspiration [​IMG]
    mike bowling, brEad, loudbang and 3 others like this.
  19. wheeldog57
    wheeldog57
    My head is spinning (more than usual) trying to keep up your frantic pace Mike!
    No flies on you brother!
    Mikel50, loudbang and patmanta like this.
  20. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    He's got a "Magic Wand"... That's it... I just know he does!
    Mikel50 and loudbang like this.
  21. Mikel50
    Mikel50
    Frantic is a good word to describe me at times. You should probably lay down lol.
    Ryan will ban me if I post up a picture of it
  22. mike bowling
    mike bowling
    triumph 1, patmanta and loudbang like this.
  23. 28TudorAZ
    28TudorAZ
    Glad to see this moving along. Haven't checked this board in a while. Mine has been in storage while I work on my dads 52 Chevy truck. Almost done and I can get back to my Tudor.
    brEad and loudbang like this.
  24. mike bowling
    mike bowling
  25. Mikel50
    Mikel50
    biggeorge and loudbang like this.
  26. Mikel50
    Mikel50
    The New home for the ever growing herd of cars.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  27. Aaron D.
    Aaron D.
    Wow man, super nice!
  28. Cliff Ramsdell
    Cliff Ramsdell
    Nice structure. What size is it? Inside shots?
    Cliff Ramsdell
  29. Ritzy1
    Ritzy1
  30. Fiftee3
    Fiftee3
    ^^^^^^^^ Me too!!!
