Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. mike bowling
    mike bowling
    I think his garage came out so nice, he put the car outside and bought furniture!
    Mikel50 and greaser like this.
  2. Mikel50
    Mikel50
    Tim, NoSurf, patmanta and 4 others like this.
  3. 55chevr
    55chevr
    Looking at the first photos in the thread I am reminded of early "Bomber" stock cars. Torch cut and stick welded. I used to build like that back in the 60-s. Scary stuff. Makes you think what exactly is a survivor and why anyone would want to save it.
    Joe
    Mikel50 likes this.
  4. Nicksibley
    Nicksibley
    That is so cool!!
  5. mike bowling
    mike bowling
    Dude! You're back!!
    ????????????????? Whussup?
  6. Mikel50
    Mikel50
    It killed me to push the sedan outside this spring. I purchased a 40' shipping container to store it in while I got some other things off my plate. Shipped my son off to college this fall and finally got myself back in a position to push it Back in the garage. Past week or so I've been "re learning" some essentials.
    So back at It and looking to get the ball rolling.
    patmanta likes this.
  7. mike bowling
    mike bowling
    Great to see you back on the thread!
    Lots of good stuff going on behind closed doors here in New England as winter approaches.
    Mikel50 likes this.
  8. Mikel50
    Mikel50
    Mike ! Ya I'm back...been working on getting the motor and trans in between the rails.
    Just wrapping my head around things all over again.
    I've been scrolling through the threads and it's pretty awesome seeing all the progress on people's cars and trucks.
    I waved the white flag for a bit.
    Seemed like every step forward I went backward...so "less is more".
    volvobrynk likes this.
  9. Mikel50
    Mikel50
    [​IMG] Measuring and measuring everything over and over before things get set in place. Runnin the 8ba so I want to make sure my fan is in the right place for the radiator. Puts the tail of the trans a lil further back, but it's all good because I'm running an open drive. I'm excited to get moving on it...
  10. Mikel50
    Mikel50
  11. mike bowling
    mike bowling
    There's a couple of threads on here where guys built their tranny mount right off the stock center X-member- I think "Pete" did it in his coupe build for the "Race of Gentlemen", Fall of 2015. And "Wheeldog57"--"Something from nothing Roadster"
    Keep bangin' away! ( and DON'T use Tardel's book for motor mount location!! at least the older edition- WRONG!)
  12. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    @BenLeBlanc did a really creative mount and X member on his frame:
    http://www.jalopyjournal.com/forum/threads/1930-ford-coupe-project.954246/page-11#post-11309391
  13. Mikel50
    Mikel50
    I made some original measurements using the book and nothing made sense so I set the motor and trans in place to know exactly where I need to be. Much more comforting seeing it mocked up than going off pages in the book. I have a F-1 crossmember I picked up and the pedal assy I plan on running. I may add some additional braces to create my own K member. I picked up (free) a nice set of A rails (front horns cut off) I'm going to use for the stock to complete it.
  14. general gow
    general gow
    MODERATOR
    glad to see you back on it. i haven't been sober since i saw you at gathering of the faithful.
    Mikel50 likes this.
  15. Mikel50
    Mikel50
    [​IMG] removed rear crossmember this afternoon after getting the frame up on 4 leveled stands. Welded it up and added the supports I made from the rolled edge of a frame rail I had. I like the look of the continuous rolled edge from the A rail up the gusset. [​IMG]
  16. Mikel50
    Mikel50
    Ha ! More where that came from Mark. I hope you enjoyed it and thank you for the use of your library.
    Much appreciated,Sir.
  17. Mikel50
    Mikel50
  18. Mikel50
    Mikel50
    biggeorge likes this.
  19. gonzo
    gonzo
  20. Mikel50
    Mikel50
    Did some work on the tops of the front horns also, someone at some point notched them for one thing or another. Tops are good but now onto the bottom side. [​IMG] used my grandfathers old molding profile scribe.
    Worked great to get the profile correct [​IMG]
    Done for tonight ... headed to NJ for the next 4 days.
    Be back at it on the weekend.
    Enjoy fellas !
    Thanks for the encouragement ... I appreciate the words.
  21. Mikel50
    Mikel50
    [​IMG][​IMG] not too shabby ... for a guy who has never done this stuff before
  22. Congratulations to you. You've definitely amped up on your skills.
    That progress is commendable.
  23. Mikel50
    Mikel50
    Spent some time on the sedan this Afternoon. Finished up repairing the front horns [​IMG]
    Got the motor mounts where I was happy with them. Placement of them puts my fan roughly 1-1/4" away from the radiator when everything is bolted down. Next step I had to rework the F1 crossmember. Made the mistake of notching the crossmember measuring from the bottom up to fit inside the rails. It was clear I should've measured from the top down. So I cleaned it up rewelded the pieces I removed then made everything fit nice and snug.
    [​IMG] my screw up.
    [​IMG]cut out a pie wedge and hammered and welded the lower edge to follow the contour of the crossmember. [​IMG]
    Really happy with the final fit, going to get it cleaned up before I weld it in place.
  24. Mikel50
    Mikel50
    Now onto steering box, pedal assembly once I lift the body onto the frame to make sure everything works.
  25. Mikel50
    Mikel50
    biggeorge, clunker and BenLeBlanc like this.
  26. Mikel50
    Mikel50
  27. mike bowling
    mike bowling
    You're on fire kiddo! Lookin' mighty fine.
    Mikel50 likes this.
  28. Mikel50
    Mikel50
    Thank you, Mike. The ball is finally rolling...planning on keeping it moving
  29. patmanta
    patmanta
    from Woburn, MA
    I like the way you fit your F1 better than how I did mine!
  30. Mikel50
    Mikel50
    Thanks Pat. I really wanted it to look factory and have the tabs folded inside the rail to allow me to rivet or bolt them as well as have plenty of surface to weld. Once I plate the frame it will all tie in perfectly. I'm a stickler for details and making things right. I was mad at myself for making the initial mistake but I'll clean it up and no one ever see it once it's done.
