Projects Progress on Rocky's 34 coupe..last update 8/16/18
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jan 12, 2009.
  1. We'll see, Scott.
    Hanging the motor to install flywheel/clutch. I was able to get an 11" disc up inside but I'm greedy...I want to use my 11.75" disc that came with my pressure plate but it needs a little trim.....center hub hits the back of the crank and it's too fat to get up in the hole. If I trim/grind 3/16ths [marked in red] off the hub it'll fit. Mrs Rocky is sleeping up in the bedroom [above the garage] so this noisy job will have to wait 'till tomorrow but I most definitely see light at the end of the tunnel!
    To be continued: 34enginehangin.jpg 34clutchdisc.jpg
    brad2v, low budget, loudbang and 4 others like this.
  2. Clutch problem solved, motor/trans in the chassis. Notice clutch and brake pedals are sticking up in the photo. They're working perfectly! I was afraid I may have gotten the pedal ratio wrong for the clutch but I can work it with only hand power...works as it should and smoothly. Same with brakes. I also replaced some brake lines I wasn't happy with and made some front motor mount "insulators".
    Uh, I totally trashed the little garage to the max [worked 10 hours] and now Mrs Rocky wants me to spend Sunday with her. Guess I'll clean up my mess Monday.Oh, and my Girling park brake caliper [the one on the ear end pinion] leaks. I'll be looking for a rebuild kit for it soon.
    ls1yj, 47ragtop, Gotgas and 9 others like this.
  3. Baumi
    Baumi
    Great work as always Rocky! Looks like you are making good progress! This will be a mean coupe
  4. Tim
    Tim
    from Raytown Mo
    I hear it rumbling away in my head already :)
  5. MMM1693
    MMM1693
    you can just feel it coming
  6. Jeez Rocky....just another old guy playing with his Lincoln Logs.
    There's the pot calling the kettle black,,,,huh?
    Looking like a REAL hot rod.
  7. bobkentourage.jpg Jeeze Charlie. It almost feels like the boys are over at my garage cheering me on. A good feeling.
  8. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Just between us Mods..... no special treatment....don't put a IFS on it or else a delete of the whole 9 year build !!! :eek:
    Plus only on yours if you bag it / don't take a picture / don't show anybody or tell anybody...... or it's gonzo...:)
    Have to bust em' on ya.
    Bwhaaa Rock... funny of course :D
    Keep going....HAMB drags...remember.
    ls1yj and lothiandon1940 like this.
  9. Well, Cob......I guess I'm gonna have to change all my plans. I was planning to send off to Morrison to get one of their chassis with wiggly suspension on both ends and swap the body off for a 'glass 3 window. Got an LS motor and 4L65 for it to go with the fully independent billet 9" third member. Should I go with imported leather or "gunny sack" interior?
    Yo Mama!
    ls1yj, slim38, lothiandon1940 and 2 others like this.
  10. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
  11. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Interior ..... rope belts with milk crates.
    To the rest of our fellow HAMB members, Mods have to cut loose with each other once and a while.
    lothiandon1940 and cactus1 like this.
  12. yup...Cob is the tall one with the yellow hat. corcobcoupehemibuy_2001.jpg
    lothiandon1940 and Bandit Billy like this.
  13. alchemy
    alchemy
    The goofy looking one? Who's the other goofy looking one? ;)
    Bandit Billy, loudbang and Petejoe like this.
  14. Tim
    Tim
    from Raytown Mo
    You know, just because.
  15. Jeff....I shall not dignify that question with an answer...
    Tim...thanks for the old video. Hope to hear it running again soon.
    loudbang and Dick Stevens like this.
  16. flamedabone
    flamedabone
    The giggle at the end gets me....
    See you in August, -Abone.
    Stogy, Tim and loudbang like this.
  17. Cruised down to Speedway and scored a 2.25" exhaust "kit" with 90, 45 degree bends and 4, 48 inch straight pieces. Nice stuff. Got the driver's side done as far as the muffler. Glad I have a cut-off saw. I mig welded all the joints except the ones I need to install/remove the system. Not sure what I'm gonna do about tail pipes but a pair of megaphones are not out of the question. Always liked that look. Behold............ 34exhaust.jpg
    brEad, cactus1, loudbang and 3 others like this.
  18. Mufflers are a pair of old Edelbrock RPM series chambered stainless mufflers. 34mufflers.jpg
    brEad, tb33anda3rd, loudbang and 3 others like this.
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Rock - mufflers... take 5 minutes and listen to the music...drums !!!!!
    It fits.
    Keep going.......
  20. You guys are having way too much fun.:D;)
    lothianwilly71 and loudbang like this.
  21. Yeah, it's true.
    lothiandon1940 likes this.
  22. Tim
    Tim
    from Raytown Mo
    I can actually hear you saying “behold” haha super stoked on this thing coming to life man
    lothiandon1940 and loudbang like this.
  23. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  24. OK, I took Sunday off to spend with Mrs Rocky and to work on my house...springtime stuff, you know like spending over $130 for lawn fertilizer, weed 'N feed, crabgrass preventer, leaf bags etc etc etc...but Saturday I got the other side of the exhaust done from the engine to the mufflers...and I ordered one of those long driveshaft slip yokes from Summit. Yeah, I blew it when I measured for my driveshaft so now I need that long slip yoke. Sigh....a 60 dollar mistake. Better to catch it now than blow off the extension housing of my muncie trans.
    ....and I found the top leaf of my front spring, now that I've got the front spring all ground, wirebrushed, painted and installed. That's ok....I really need to make up a 1" spacer between the crossmember and the spring. It sits just a leetle bit too low in front.
    brad2v, 47ragtop, Tim and 4 others like this.
  25. GordonC
    GordonC
    Rocky I feel your pain on the driveshaft. I "may" have gotten my drive shaft an 1/8" too long so I may have to see if I can have that much taken off the end of the yoke for some relief. Not sure as I just got the car running and haven't been out on the road yet.
  26. If my new yoke is too long I'm just going to use my chop saw to get the desired length. No biggy.
  27. flamedabone
    flamedabone
    When you order the wrong parts, the yokes on you.
    -Abone.
    loudbang and GordonC like this.
  28. atch
    atch
    ouch! That one hurt.
  29. Groan.
    loudbang and Tim like this.
  30. Mrs Rocky left to have lunch with the girls and I went out to the garage to make up muffler hangers. I used what I had lying around...some new shock mount rubbers, a hunk of 3/16ths I found on the street one day and after measuring, welding, drilling and eyeballing, VIOLA! I had made 1 of 4 hangers. It's solid but not too solid as to transmit vibrations into the car. Only 3 more to do and the 1st only took me about 4 hours!
    Afterward I realized I hadn't gotten dressed...I did all this shit in my shorts, slippers and a T-shirt.....yes, it was my "beater" 1st generation black hamb shirt. 34mufflerhanger.jpg
    Stogy, GordonC, Dick Stevens and 4 others like this.
