Projects Problems starting 46 chevy truck with 216 engine
Discussion in 'Traditional Hot Rods' started by Gus Hoel, May 24, 2017.
  1. Gus Hoel
    Gus Hoel
    I'm having a real trouble starting this truck it gets really good spark and I've hooked up an auxiliary gas tank. I can't seem to find the problem and i'm not prepared to restore it if the engine can't run. If anyone has any suggestions please tell me them
  2. blackrat40
    blackrat40
    Those old Chevys had a fiber gear that drives the cam. They frequently failed.
    With the valve cover off, check that the valves are moving when cranking it.
  3. Engine man
    Engine man
    from Wisconsin
    If you have spark I assume the cam is turning. Is the carb squirting fuel? Have you tried pouring a little gas in the carb? There should be a fuel filter in the carb that might be plugged.
    Hnstray likes this.
  4. panheadguy
    panheadguy
    from S.E. WI
    Won't run if no compression. Check that out first. fuel + spark + compression.
