Hot Rods Primer and Painting Question
Discussion in 'The Hokey Ass Message Board' started by Ford52PU, May 9, 2020.
  1. Ford52PU
    Ford52PU
    from PA
    I completed the bodywork and primed my 52F1 back in September of 2015. Since then its lived in my garage. Bed off waiting for me to contiinue. Life got in the way, but now with some serious downtime due to the China Flu I'm hoping to get back on it. The last thing I did was sand it all over with 400. If wipe it all down with prepsol should I be ok to spray paint or do I need to start over. Its never gotten wet been outside in the weather since priming.
    reagen likes this.
  2. john worden
    john worden
    from iowa
    For piece of mind I would sand it again.
    Ford52PU likes this.
  3. BJR
    BJR
    Just go over it with a scotch pad, and you should be good to go.
    Tri-power37 and Ford52PU like this.
  4. I’d at least hit it with a scotch brite pad..maybe some
    400 on a Da with a soft pad and interface combo..
  5. Rckt98
    Rckt98
    What was it primed with? Epoxy hopefully.
  6. oldolds
    oldolds
    Yes, a light sanding, with at least a scotch-brite pad. you need to clean out the scratches.
  7. anthony myrick
    anthony myrick
    I rescuff anything that sits more than 24hours after being prepped for paint.
    I would re sand.
    It’s cheap insurance.
    john worden and Ford52PU like this.
  8. lippy
    lippy
    from Ks
    What kind of primer? Urethane? Lippy
  9. AngleDrive
    AngleDrive
    from Florida
    First thing is wash it good with soap and water. Then use a good pre cleaning agent. Scuff the primer with at least 320 grit.
  10. Ford52PU
    Ford52PU
    from PA
    thanks for all your replies.
    Its a Urethane primer. I guess I'll give it a bath and a resand and go from there.
  11. anthony myrick
    anthony myrick
    Urethane primer scratches will try to close up / lose their tooth over time when left open.
    As far as cleaning goes, I do a two step process. Alcohol based or water based cleaner followed by a wax and grease remover.
    A good home remedy is also an ammonia based glass cleaner.
    The wax and grease remover sold at the chain parts stores are too “hot” in my opinion. They will attack/soften primers in my experience.
    Ford52PU and ras like this.
  12. lippy
    lippy
    from Ks
    I'd sure take all that tape and paper off and trash it. After you get it sanded re-tape and paper after cleaning it good. Lippy
    john worden and anthony myrick like this.
  13. Pats55
    Pats55
    from NJ
    This truck sat in primer for 5 years. I'm not here to sell a can of paint. I would da the entire vehicle down with 220. I do want to know what is under that primer. I would primer with 2 coats of the permanent rust sealer primer then reapply a surfacing primer over it. That's what I would do.
  14. Pats55
    Pats55
    from NJ
