1937 Plymouth, 350 engine, two speed powerglide. It runs drives and stops. I was in the process of putting airbags in the rear, I broke my hand and only got as far as a test fit. The trunk will have to be cut in two places so the bags don't rub. I took them off and put the springs back on. I'll include the bags and the lines. All you have to do is re-mount them and cut the trunk. Has new firestone wide whites, beauty rings and moon caps. Sound deadener is installed, just needs the interior roof and doors. There is wood already in place to upholster the rest of the inside. Only has front glass. Needs a hinge on drivers door, but the door still opens and closes with the other hinges. Someone put bondo over some bullet holes in the rear trunk. Also, the top has bondo where the chop was done. The fan on the interior works on a switch as well as interior lights(the whole inside glows red at night). The stereo works. I also have a fan shroud that I was going to install, just didn't get the chance. I'll throw that in as well. I have a clear texas title in my name. 17000 obo. Thanks for looking.
