Projects Prefect / Willys Gasser Build.
Discussion in 'Traditional Hot Rods' started by Mitchell Rish, Jan 6, 2015.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
  2. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Gonna run a 4500 plus converter. No transbrake.
  3. I bought 2 glides to build, be good to learn on, one is for Thames. I have to relocate the steering box for clearance.
  4. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Should fit where you 4 speed fits. What’s hitting ?
    loudbang and GlassThamesDoug like this.
  5. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Spent yesterday after church at an old track that many an early fx/funny car went down. Was good to get out. Got see to the track operator that started it all for me as a kid. His health had taken a very serious hit. God restored him. None other than Mike Franks. Yes his father was Mr Carlton Franks. Fulton/Blue Mountain/and Byhalia drag strips to name a few.
  6. 390S code steering box, in 24in wide frame rails. need to move steering box up under engine to make tranny, and leg room. Then car goes back together.
  7. Getting road dust on it, so I can call it a barn find..... automatic will make this car useful.
    enloe, catdad49, tomkelly88 and 3 others like this.
  8. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Gotcha. Sound like you have planned it out.
  9. I have 2 glides, and a T400HD short tail hsg.. option for it.
  10. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Rotating assembly for Prefect is together. Got a head bolt hole that I don’t like the way the threads look.Gonna put in a heli coil and then seal and run studs. I can tape everything off and go from there. Better now than later. I used a thread chaser on everything before the crank etc sent in. Light hit it the right way and the bottom three threads look ok but the top 4 or 5 nit so good. Gonna fix it now.
  11. Thats some domes there...
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
    .490 to be exact.
    GlassThamesDoug and loudbang like this.
  13. Mitchell Rish
    Mitchell Rish
    from Houston MS
    AND that's a spiffy looking New shop in the background.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Gotta pull the short block back down for the Prefect. . Everything checks out perfect but due to luck I had a head bolt hole in the block that pulled the threads. Gotta heli coil it. Then studs. I’ll pull it back down and clean up after the fix. No point in taking a chance.
  15. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Installed heli coil. It went in very well. Used a home made drill and tap guide. Framing square says the stud I screwed in is dead perpendicular as it should be. I pulled everything down to clean and wash. I am taking the rods back to check the small end. Need to be rehoned. They are tighter than I like. I have a second set from
    Inventory just in case these don’t do as I want. I also want to narrow the big ends a little.
