PPG, Dry time ?
Discussion in 'The Hokey Ass Message Board' started by Bob 1743, May 14, 2012.
  1. Bob 1743
    Bob 1743
    How much dry time is needed between coats with PPG , JAU , Acrylic urethane ? Temp. will be about 75 degrees.
    Is humidity a factor ?
    Thanks,
    Bob
  2. Caddy-O
    Caddy-O
    Bob...
    The last PPG single stage I sprayed had a flash time of 15 Minutes between coats...
  3. SS350Sport
    SS350Sport
    from Utah
    Answered the same question yesterday:
    PPG product sheet JAU Direct Gloss Acrylic Urethane
    Dry times between coats
    5 - 10 minutes at 70ºF (21ºC)
    Air dry
    Dust: 45 min
    Tack:3 to 5 hours
    Tape: 12 hours
    Dry:16 hours at 70ºF (21ºC) to polish and put into service
    Clear: 4-6 hours
    Force dry
    30 minutes at 140ºF (60ºC), wait 8 hours to
    polish and put into service.
    IR 10 - 15 minutes
  4. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    As long as the Humidity is not above 65% (as a rule of thumb).
    If the Humidity is higher than 65%, give the flash time an extra 5 -10 minutes.
    You are still well within the window.
    Happy Spraying,
    VR&C.
