Power Rack & Pinion Oscillating Violently, Help!
Discussion in 'The Hokey Ass Message Board' started by 1gearhead, Aug 2, 2011.
  1. 1gearhead
    1gearhead
    This may not be entirely HAMB friendly, but here is my problem. Have 34 Ford with MII front Suspension with power Rack & Pinion Steering. After having the rack & pinion rebuilt because it was leaking fluid and replacing the old cracked hoses the steering oscillates back and forth violently on its own when you start the car. I have been told that this is due to air being in the R&P. OK, I'll buy into that. What I want to know is how do you get it out? And if it's not air in the system what is causing the problem. Hoses are not reversed. R&P has been gone through twice to check and/or replace valves. It's driving me crazy, I just can't believe it's that tough. Can any one help me out here?
  2. need louvers ?
    need louvers ?
    Are you absolutely sure the hoses are not reversed? That's the only time I have seen this problem... Always happens on the hardest to work on cars too...
  3. terryble
    terryble
    from canada
    Might be a valving problem, try tuning the steering wheel lock to lock holding it briefly at each extreme
  4. 1gearhead
    1gearhead
    Surely someone has run into this problem before. How did you cure it?
  5. tommyd
    tommyd
    from South Indy
    Fixed it by reversing the hoses on the rack.
  6. badshifter
    badshifter
    Correct. You got them wrong. And, DON'T TOUCH THE WHEEL! You will break fingers, thumbs etc. Swap the hoses and move on. Simple fix for a simple mistake.
  7. paintcan54
    paintcan54
    I had a friend his done the same thing when he hooked it up, reversed the hoess and it fixed it.
  8. hinesenhoffer
    hinesenhoffer
    from kentucky
    On my mustang 11 rack there is two different size fittings so you can't hook them backwards. I think you have a internal valve problem.
  9. flamed34
    flamed34
    He said he replaced the hoses. If he had them made wrong, it's easy to swap.
    Typical of reversed hoses. My father just made the same mistake.
  10. green53ford
    green53ford
    from Wisconsin
    Had the same problem on a 38 chev. Reverse the hoses.
  11. tucknroll
    tucknroll
    from iowa
    i vote for the hoses. seen it done. good way to break your fingers that wheel oscillates fast.
  12. T McG
    T McG
    from Phoenix
    Easy to check, the return line goes to the fitting closest to the u-joint
  13. lines are backwards as said before. Any one that has messed with these knows, and those that have not. Should listen to those that have.
  14. micky69
    micky69
    from Ohio
    Ususally if the hoses are reversed the rack will take off to one way and lock. Oscillating, like quick movements back and forth usually mean the valve in the rack is bad or seals in the rack are not holding pressure. Thats usually the problem with the rebuild racks and why we ended up manufacturing our own units at Flaming River.
  15. Xtrom
    Xtrom
    from Forman, ND
    Reverse hoses. Sectors do the same thing when you reverse them.
  16. tucknroll
    tucknroll
    from iowa
    hey 1gearhead any update on problem? hoses right?
  17. mattcrp1
    mattcrp1
    is there air in the system? the 1998 ish explorers are famous for wild oscilation after service to the system and the air needs to get out of the system. maybe vacume the system or check the fluid for aeration.
  18. 1gearhead
    1gearhead
    You guys were right. Reversed Hoses!!!!!! The Hose Shop switched the ends when they manufactured new hoses for me. Reversed them back problem solved. Thanks
  19. sdetweil
    sdetweil
    from austin, tx
    thanks.. just ran into this myself..
    I put adapters to AN fittings on the rack, so they are the same..
    the seller told me the smaller (9/16) port was the pressure port,
    but that is the one closest to the U joint..
    will swap them later today..
    Sam
  20. Blue One
    Blue One
    from Alberta
    :rolleyes:
    Look who the "experts" were this time. How many posts said reversed hoses ??
  21. sdetweil
    sdetweil
    from austin, tx
    swapped mine last night and it works fine now.. thanks!
    Sam
