Technical Possible to make your own windshield gasket?
Discussion in 'The Hokey Ass Message Board' started by Sean Edwards, Nov 9, 2024.
  1. Sean Edwards
    Sean Edwards
    Hey everyone, my '48 Cadillac Series 61 4-dr needs a new windshield gasket if I ever expect to get caught in the rain. After much research, I've only found one source for a gasket for this 2-piece windshield at $445. Considering I also need a new windshield and both are unique to 1948-49 and crazy expensive, is it advisable to try and fabricate a windshield gasket on my own? A one-piece rubber gasket obviously has no seams and less risk of leakage, so am I wasting my time thinking about doing it myself?
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
  3. Mr48chev
    That is where he found the one for 445.39
    Sean, you might see how close you can come with the Universal rubber that they use around tractor and combine and equipment windows. Glass shops that replace windows in those usually have a few styles in bulk rolls. Screenshot (1537).png
  4. Sean Edwards
    Sean Edwards
    Those guys do seem to have everything but they do want $445 for this item. Thanks for the advice though.
  5. Sean Edwards
    Sean Edwards
    Good point! I should be able to find a glass business that does that in rural Oklahoma where the car and my workshop is.
  6. squirrel
    I'd be interested in how you plan to make the gasket. The bulk seal is available from Steele for $10/ft, and you need 14 feet of it. Then you get to figure out how to make the parts where the wipers poke through, and how to make the center part, and how to join the corners.
    The bulk materials is available from several sources, here's one that's close but might not be wide enough for the 1/4" glass you have
    https://www.amazon.com/Rubber-Seal-Locking-Windshield-Equipment/dp/B00NUHRE6S?th=1
    But seriously...you could clean the old one very well and spend some time with RTV filling the gaps, and get it to almost seal...and save up your money until you can afford to buy the gasket.
    good luck!
    Sean Edwards and Bangingoldtin like this.
  7. Budget36
    Budget36
    ^^^^^ or sometimes you just have to save and pay the price.
    abe lugo, Sean Edwards and alanp561 like this.
  8. Clydesdale
    Clydesdale
    ^^^^^ agreed!
    you have picked a Cadillac after all!!!
    Budget36 and alanp561 like this.
  9. If you are planning to keep the two-section windshield with center divider and replacing the glass, my advice is-
    1. Buy new glass.
    2. Buy the gasket.
    3. Have a professional install it.
  10. ALLDONE
    ALLDONE
    don't think I can tell you what kinda car.... but... they in stall with urethane and tape around the edge and it looks just like rubber when done...
    Sean Edwards likes this.
  11. squirrel
    That's probably on newer cars that have a different design...where the glass is larger than the opening for the glass....I doubt it's gonna work on this car!
  12. rockable
    rockable
    If you don't apply a sealant on both the pinch weld side and the glass side, it will leak. Ask me how I know.
  13. Sean Edwards
    Sean Edwards
    Very good point. I just wanted to check with you guys and see if fabricating your own gasket was common.
  14. Sean Edwards
    Sean Edwards
    Will do!
  15. Okie Pete
    Okie Pete
    If you try to use universal gasket in a roll make sure the grooves are the correct depth and width. I tried to use the universal gasket in a roll on my 66 KW . The groove for the pinch weld lip on the cab wasn’t deep enough and the glass would pop out. Sometimes it’s best to spend the money and get the right part .
  16. gene-koning
    gene-koning
    Is that 2 piece windshield flat glass, or curved (I know nothing about a 48 Cady)?
    If its flat, and you need to buy the glass anyway, I would at least look into having the glass cut oversized and bonded in. You would need to fabricate a center support. I have had better luck getting leak proof glass in cars with bonded in glass, as opposed to glass on rubber gaskets.
  17. RodStRace
    RodStRace
    It's one of those things that pretty much requires the exact right part.
    Any person can cut out a regular thermostat gasket, but few would risk making their own head gasket.
    You are asking about a part that not only needs to seal, but also support a big sheet of glass directly in front of the people inside.
    Be glad that someone has gone to the effort of reproducing it and that you have the choice.
    Yes, it's expensive, but the cost is easily explained. Do you want to take exact measurements, create a form, fill it with your choice of material and pop one out?
    Sean Edwards and Tow Truck Tom like this.
  18. Checked the same year Buick gaskets and they are nearly the same price. 420.00. Just save up.
