Technical portable/garage lift.
Discussion in 'The Hokey Ass Message Board' started by eddie rockitnyc, Mar 20, 2017.
  1. eddie rockitnyc
    eddie rockitnyc
    from nyc
    hey guys,
    can anyone recommend a small home/garage lift?
    looking at Harbor Freight scissor lift,BendPak,EZ Car Automotive etc.
    would appreciate any insight on these.
    thanks. Eddie-Brooklyn NY.
  2. topher5150
    topher5150
    What about something like this little guy?
  3. eddie rockitnyc
    eddie rockitnyc
    from nyc
    yes. something like this. have you tried it?
    thank you.
  4. topher5150
    topher5150
    eddie rockitnyc likes this.
  5. okiedokie
    okiedokie
    from Ok
    Might take a look at Kwik Lift.
  6. seb fontana
    seb fontana
    from ct
    GregSmithequiptment.com......Really happy with the one [4 post] I got..Several different heights, widths and lengths to choose from..Good adjust ability in cables and hanging lock rails to adjust for level..
  7. Jkmar73
    Jkmar73
    from Tulare, CA
    I have the quick jack setup. Works great. Lifts the car about 2 feet off the ground. Plenty of height for rotating tires, brake jobs or oil changes.
  8. Flat-Foot
    Flat-Foot
    from Locust NC
    I'm not getting under anything supported by a harbor freight lift. Not a chance!
  9.
  10. KoolKat-57
    KoolKat-57
    from Dublin, OH
  11. tom in nh
    tom in nh
    If you want quality, look for a Mohawk. I believe that their headquarters is in New York.
  12. I have a Snap-on (bought it used) its made by Wheeltronic
    works great and perfect for body work
    also makes a nice weld/jig stand
  13. blowby
    blowby
    from Nicasio Ca
    ^^Looks like the lift that Harbor Freight copied. Nice that it needs no structure work and is portable but doesn't have room to work on anything underneath (probably a good thing). Also 7" minimum clearance. HF reviews are overwhelmingly positive, opposite of what I would suspect.[​IMG]
    scrap metal 48 likes this.
  14. dan31
    dan31
    I have a "Direct Lift " 4 post with a sliding jack. It has wheel attachments so that you can move it around if you need to .
  15. blowby
    blowby
    from Nicasio Ca
    ^^ I see he made some nice blocks to get around the minimum clearance issue. A major attraction to these scissor lifts is portability. I plan to move as soon as my 90 yo MIL moves on (although she'll probably outlive me, hope she can use a lift). But for me the main reason for a lift is drivetrain work, wheels and suspension I can handle with jack stands. I also wouldn't feel comfortable underneath, even if there was room to work.
  16. nochop
    nochop
    from norcal
    I don’t see he point of that, unless you have a bad back and need to change brakes or clean the whitewalls
    tb33anda3rd likes this.
  17. Me and you both brother.
    Quality control is something that is sorely lacking when it comes to harbor freight.
    At least this HF piece didn't fall on me but lasted about a hour,took long than that to build the stand. HRP
  18. blowby
    blowby
    from Nicasio Ca
    Wow, did it come new with all the scratches and corrosion?
  19. zzford
    zzford
    One good thing about a Harbor Freight lift is, if it fails, and kills you, they will give your widow a new lift.
    TagMan, Blue One and blowby like this.
  20. southcross2631
    southcross2631
    Hard to change a transmission on a scissor lift.
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have the Quick Jack. Works nice.
  22. for the price of one of those, you could buy 12 jack stands, a good jack, a Da, a good impact gun, some fender covers, a drop light, a creeper and still have money left over. or save up for a real lift.
