pontiac mounts?
Discussion in 'The Hokey Ass Message Board' started by mooseknuckle, Aug 19, 2011.
  1. mooseknuckle
    mooseknuckle
    from Santee
    I was wondering if anybody could tell me the approximate distance between the mount perches on a pontiac v8 350-455?
    if im not making any sence let me know haha
  2. mooseknuckle
    mooseknuckle
    from Santee
    or if its the same distance as any other motor, like any othe BOP? or anythin else?
  3. 55chieftain
    55chieftain
    I was using the early style pre-69 I believe GTO mount where the insulator is on the engine side and if I remember 16 1/4" . I think thats the same like a sb Chevy if your looking to use a engine mount crossmember? The space in the mount is about 4" wide so it would have to have a spacer. The later style mount the insulator was on the frame.
    If your engine is still on your stand like in your avatar , mock up the mounts on the engine and make a cardboard template to figure the exact differance.
  4. mooseknuckle
    mooseknuckle
    from Santee
    thats what i needed to know. yeah, a cross member was exactly was i was looking at. il get to work on that cardboard template. thank you very much.
    Iv seen your threads alot on the hamb while searching for pontiac info. i dig the front timing cover motor mount plate that you use. your poncho's pretty sweet!
