Technical Pontiac Head Question
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Mar 17, 2020.
  1. 31hotrodguy
    31hotrodguy
    Hmmm I think 670’s would put me right about in the same place as my current 797’s on the 389.
  2. No help on the heads. But i had a 1968 pontiac 350 HO, which i believe had the ram air III heads and man, that thing moved!
    Sent from my SM-G965U using The H.A.M.B. mobile app
    31hotrodguy and Deuces like this.
  3. Deuces
    Deuces
    Pictures????..... :)
    31hotrodguy likes this.
  4. Joe H
    Joe H
    I haven't checked any of the aluminum heads, but I have heard the new " D " port heads run decent. The early aluminum heads along with the racing heads have big runners, the velocity through them is terrible till you get the RPM way up. The newest " D " port aluminum have small runners. Here is a link about the new KRE heads,
    http://www.tinindianperformance.com/kauffman-aluminum-d-port-pontiac-cylinder-head/
    With any aluminum head, you can run at least 1 point higher compression on the same fuel as you would iron heads due to the rapid heat dissipation.
  5. saltflats
    saltflats
    from Missouri
    :cool:
    Elcohaulic, Deuces and 31hotrodguy like this.
  6. Deuces
    Deuces
    Cool! Thanks for posting those.....:cool::)
    31hotrodguy and saltflats like this.
  7. derbydad276
    derbydad276
  8. Elcohaulic
    Elcohaulic
    Those 1967 670 heads are the ultimate... Put on a set of those heads with a fresh 068 cam and have fun..
  9. 31hotrodguy
    31hotrodguy
    Still learning about Pontiac as I go. Especially when it comes to the heads. My Chevy brain is going in circles trying to figure out which heads are better than others.
    So are the 670 heads basically the same as the 16 heads in 68? A lot of the heads have the same size valves but do they flow the same?
    And how do they compare with say the later large chamber heads like the 7K3 or the 6x?
    This is keeping me up at night? Lol
    Deuces likes this.
  10. Deuces
    Deuces
    Yeah and how do those heads compare to the 405 h.p. + 421 heads????..... :)
    Inquiring minds want to know.... :confused:;)
    Elcohaulic and 31hotrodguy like this.
  11. 31hotrodguy
    31hotrodguy
    I guess I can always buy “the” Pontiac book online for $300 plus dollars!
  12. Johnboy34
    Johnboy34
    from Seattle,Wa
    Have you stuck a bore scope in a spark plug hole to see what pistons it has?
    Sent from my SM-G973U using The H.A.M.B. mobile app
  13. 31hotrodguy
    31hotrodguy
    Not yet. I currently don’t have a note scope. I need to order one.
    Johnboy34 likes this.
  14. 31hotrodguy
    31hotrodguy
    I meant bore scope but for some auto correct didn’t like that. They are definitely cheaper than they were a few years back.
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    Since you aren't (or are you?) going class racing, you probably won't notice much difference in any of the large valve heads. I would be more concerned about getting the compression ratio where you want it, than picking the absolute "best" head. Bear in mind that rebuild costs may get you close enough to aftermarket new to make that option the best one.
    However, that really doesn't answer the question, hopefully someone will come along that will be able to.
  16. Joe H
    Joe H
    Even racing, stock heads will all perform about the same. In '65, the good heads were #093, used on both 389 and 421's with 68 cc chambers. 389 was rated at 10-1, 421 was rated at 10.5-1 compression, yet all the charts show 1/2 point less actual compression,dad and I have found this to be true on most of the heads we have checked over the years.
    This is my dad's book, https://www.amazon.com/How-Build-Performance-Pontiac-Design/dp/1884089674 , wish we had some more of them, I could make pretty good money selling at this price!
  17. 31hotrodguy
    31hotrodguy
    I’m not planning on class racing. I would like to run the car but just for fun. Plan now is to get it running with the stock63 389, then go bigger within the next year or two. Just a fun stock looking street car.
    I’m just trying to figure out the Pontiac heads in regards to is it worth it to try and find a certain head and pay the money or can I go with some of the other less coveted heads and still make good power.
    Scott
  18. 31hotrodguy
    31hotrodguy
    Awe yes, how many times did I walk by that book on the shelf at the book store only to think “I’ll buy it next time” only to see it now advertise for $300 plus!
  19. s55mercury66
    s55mercury66
    from SW Wyoming
    I would most certainly say yes, go with a set of big valve heads, and you should be most happy. The large chamber 6X heads you already have would probably work well on a 455, if you have a set of 16's, those might work well with the 389 combo, check the compression ratio, it might be close, but doable. Camshaft choice may be helpful if compression is too high, your manual trans will work in your favor there.
  20. Starlinerdude
    Starlinerdude
    from Washington
    There are few different early- mid 70's vintage heads that would work well with a 389,the ones that were original equipment on Pontiac 350's typically had a chamber size of 87-93 cc,some 400's had a chamber size of 96-99 cc these could all be brought down 87-90cc range without excessive milling,you may have to install larger valves a lot of these heads had the smaller valves.If you do plan on installing larger valves on a set of heads make sure you do that prior to doing any cc measurement because larger valve heads can change that.
  21. saltflats
    saltflats
    from Missouri
    And change them to 45 degree valve and seat angle.
