Pontiac beltline trim on a Chevy 1954
Discussion in 'The Hokey Ass Message Board' started by SCR8PINHRD, Apr 12, 2010.
  1. SCR8PINHRD
    SCR8PINHRD
    from delta pa
    I found a nice set of 1954 Pontiac beltline trim that I would like to put on my 1954 Chevy 2 door. Does anyone know if it's a exact replacement.
  2. kkoacolonel
    kkoacolonel
    from Union,NJ
    Yes,if the lines on both beltline mouldings match up,it will fit.
  3. SCR8PINHRD
    SCR8PINHRD
    from delta pa
    Not sure if I understand that response.
  4. Gerg
    Gerg
    as far as i know the only difference between the two is the bumpers tail lights and doghouse everything else is the same.
    Correct me if i am wrong somebody but that would all line up then
  5. The belt trim should bolt on fine. My '50 Chevy has most of the windows out of a Pontiac in it, they shared shells in 53-54 too.
  6. choppermatt
    choppermatt
    i have the same. youll probably have to cut the Chevy trim and lap the Pontiac trim over. it has a weird clip that most likely im am going to make. to hold it on the belt line under the quarter windows. its very similar to the Chevy molding.
  7. PegLegStrick
    PegLegStrick
    You can get that weird clip from these guys .... pontiacparts.net
  8. leaded
    leaded
    from Norway
    I got a friend with a Chevy 210 -54, and he have Pontiac beltline moldings, it fitted straight on...but yes some changes in clips, he used some others who fit...
  9. gas pumper
    gas pumper
    No way :D Send it to me and I'll try it out on mine and let you know:)
  10. SFO
    SFO
    from Novato, CA
    Anyone ever get info on these clips?
  11. 49ratfink
    49ratfink
    these clip questions come up all the time. any auto body supply store will have a bunch of different clips in stock, and could probably order obscure ones if needed.
