TANKS Polyethylene gas tank, 27" X 17" X 9-1/2" with sending unit, mounting bracket with straps that will fit under bed behind rear end on '47-'55 (1st series) Chevrolet 3100 pickups. Pictures show it mounted in my 1st series '55 & after removal. Filler tube is 16" & filled from the driver's side rear fender. Worked perfect with 350ci w/Holley carb & stock fuel pump.
