POLL: Filled cowl vent Yes? or No?
Discussion in 'The Hokey Ass Message Board' started by fleet-master, Jul 14, 2013.
  1. Cover over the hole
    9 vote(s)
    4.9%
  2. Find or make a new lid
    173 vote(s)
    95.1%
  1. milner3268
    milner3268
    from buffalo NY
    NO NO NO !!!!. When I chopped my 32 I kept the cowl vent ,opening winshield,and roll down back window . Open them all and it will blow your hat off.I just scored a 34 5 window,un chopped out of florida it has a opening windshield,working cowl vent AND air.
  2. falconsprint63
    falconsprint63
    from Mayberry
    I'm in the minorty I think. I'd fill it. I like AC (I'm running factory caddy ac on my 57 365 for the traditional police). My avatar has a new gasket and pours water in like crazy (as has every other car with a vent I've ever owned) The 34 truck I'm rebuilding was filled back in the 70's and will stay that way.
  3. Rusty O'Toole
    Rusty O'Toole
    If the lid is rotted off would it be easier to put an air scoop over the hole? Or wire mesh, with a drain underneath like later model cars?
  4. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    I keep them on all cars that have them. I prefer the real air over conditioned air. They are a great way to move all the heat from the engine right out of the can too.
  5. need louvers ?
    need louvers ?
    falconsprint63 beat me to it! I was going to ask if you were going to do A/C. I live in the desert and while you guys talk about pleasant summer days and kickin' the cowl vent open and feeling the breeze, that doesn't work so well when it's about 120 or so. When I did the A/C in the Plymouth about ten years ago I took great pains to keep the factory cowl vent operational. It wasn't easy as I had to off set the entire mechanism to the drivers side to get enough room for my evap unit under dash. Two problems came out of this deal though. When it is 105-120 out (about four months a year) I constantly have a small bit of extremely hot air that finds it's way through the vent's seal and reduces the efficiency of my A/C. That's with a new gasket and everything adjusted "just so". Annoying as hell to be cool and comfy driving down the road with only your right knee cap on fire in a blast furnace! The other is that because I needed such a big unit (heh huh... He said big unit...) to cool my rather extreme conditions, it blocks off most of the incoming flow when the cowl vent IS open. Kinda sucks to open it up and not feel too much airflow coming through after all that work.
    Just some food for thought...
  6. TheEngineer
    TheEngineer
    from New Mexico
    I vote make a new lid or find a replacement. I wish I had one on my OT GMC with a busted AC. The best I can do is stick my hand out the window and cool it off.
  7. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    One of the first things I did.....then shortly there after in a conversation with Uncle Ray he says "yah we filled in that hole in the cowl, I shoulda never done that, woulda been nice to have the fresh air down there".....DOH!
    To late now....
  8. junkyardjeff
    junkyardjeff
    You will be sorry if you fill the cowl vent,I needed it on my 37 Chevy p/u as it seemed to flow more air then cranking the windshield open and was much quieter too. Since I am still running a stovebolt six in the 37 I installed the splash pans on the sides of the motor and I do not have to open it now as the firewall seems a little cooler.
  9. fleet-master
    fleet-master
    well I'll be darned ! I thought the split would be a bit more even than its turning out.
    The weather here is relatively cool much of the year. 30+-degC (80degF)is a hot day here. Mostly its 10-20degC. Winters can be fairly wet and the truck is gona get regular use.I do have wing windows ...but it is a chopped n channeled cab..hmmm
    So I'm still not too sure.
  10. MAD 034
    MAD 034
    from Washington
    As many others have already said -- cowl vents are quite functional and add to that old car charm.
  11. b-bob
    b-bob
    I am really glad I have my cowl vent working. A quality gasket and the handle adjusts so I can pull the lid in tight to the cowl/gasket. No vent windows in a '39 to open.
    Even up here it gets pretty damn warm in the summer, just make sure your floor is clean or you may get a lot of crap blowing up from it.
  12. I love how my cowl vent looks, shut and open, but with no side windows, its not real functional. It is a worry when its raining, as it leaks all over my wiring. I voted fill, as i wanted to balance the voting for ya! Lol.
  13. Come on Paul, a man of your talents should be able to repair the cowl vent with your eyes closed. No fill, keep that vent in there as Ford intended.
  14. n.z.rodder
    n.z.rodder
    Cover it to keep the snow out!
    Scotty
  15. Muttley
    Muttley
    Keep it, they look cool and keep you cool. I HATED the filled cowl vent in my old '39 Coupe.
  16. Used to ride around in a sbc deuce truck with filled vent. Summer bummer.
  17. I,m adding a cowl vent to my Model A. I think every car/truck should have them. -Fat Chico .
  18. 30FordNerd
    30FordNerd
    Don't fill it, might get hot in summer but its your car so you do what you want with it.
  19. Its snowin somewhere down this island today. Cold as, im stayin by the fire. Got that hole filled yet? Lol.
  20. fleet-master
    fleet-master
    pondering.... :D might have to play paper scissors rock on this one :p
  21. mine is not working now and my truck is hot as hell. I like them and think they should be kept, unless its a non driver or you run a/c, I feel it is a must
  22. You inside by a fire too? Snow must be down your way. Nice and sunny here. Best i get some work done after lunch. Might go seal up my cowl vent. (joke, well maybe...)
  23. fleet-master
    fleet-master
    not snowing today but theres still traces on the hills from the weekend..brrr
  24. rburkham
    rburkham
    That's weird that I see this post tonight. I have a 40 international P/U that I just got the cowl vent un-glued and working. I like it to be operational. My only issue is that I have tried a couple of rubber gaskets from restoration specialties and other sources. I can not get the cowl vent to seat like it should . Seems that these gaskets are to thick. I'm looking for rubber or gasket material that will work in my application. I like the cowl vent as well as my roll out windshield to be functional. I saw keep it.
  25. 296ardun
    296ardun
    filled the cowl vent on my '34 sedan delivery, lived in SoCal, summer heat and no vent! Only good thing was that the girls who rode with me got so hot they started shedding their cloths, but not enough of them.....so wish I had kept it functional!
  26. MoparJoel
    MoparJoel
    I forgot to add, It makes a great place to put emblems :D makes the difference for someone mistaking my Dodge for a Chevy truck for the one millionth time. and Also being that its the only way I can cool my trucks cab down in 120+ degrees on Phoenix, AZ and it does fine I have never thought, I would rather have A/C than my vent. I also love when people come up to me and ask "What the hell is that hood scoop thing?!"...:cool:
  27. Dane
    Dane
    from Soquel, CA
    x3 ^
  28. n.z.rodder
    n.z.rodder
    Same here, was supposed to do a half marathon on Sunday but was postponed to this coming Sunday, some thing about snow to 200m:D
    Trad rods have them open, Customs have them filled:cool:
    Scotty
  29. mgtstumpy
    mgtstumpy
    OEM in both the 35 phaeton and 46 sedanette. Nothing like factory AIR.
  30. Ed Wrath
    Ed Wrath
    Wish mine wasn't filled.....Keep it!
