Technical polishing large items
Discussion in 'The Hokey Ass Message Board' started by jeffgies, May 1, 2014.
  1. jeffgies
    jeffgies
    Can the cotton buffing wheels that usually get mounted in bench grinders be installed in something portable? I want to polish a larger item (beer keg) which would be awkward to hold for long periods of time.
  2. Rusty O'Toole
    Rusty O'Toole
    Is an Airstream trailer big enough? How to polish your Airstream with a Porter Cable polisher from Harbor Freight and a few accessories from Home Depot.
    http://www.airstreamguy.com/polishing_info
    Your tank should be a breeze compared to this.
  3. mcmopar
    mcmopar
    from Strum, wi
    I held my keg in front of my baldor pedestal grinder, worked great. If I can do you can to i'm only a 150#.
  4. jeffgies
    jeffgies
    I'm thinking you won't be able to directly see the area being polished.
  5. plym49
    plym49
    from Earth
    Suspend it from above like the heavy power tools are suspended on an assembly line.
  6. slammed
    slammed
    Large buffer, white wool pads, heavy compound (to start) may need to sand (hand/DA) surface 1st. Silica is evil wear a mask, long sleeves.
  7. ROADSTER1927
    ROADSTER1927
    Get buffing wheels for what ever hand grinder you happen to own. Gary
  8. slammed
    slammed
  9. Rest it on a table with a blanket on it.
  10. trbomax
    trbomax
    Ive done a few aluminum saddle tanks from semi's.I just used my air buffer that I would use to cut paint with a wool pad and 3m super duty compound. The sd compound is a bit too harsh for paint but really does a number on aluminum.
  11. Unkl Ian
    Unkl Ian
  12. The short answer is yes...the same wheels used on pedestal polishers can be used on hand held. I use 8" on a makita sander/polisher. I've polished literally hundreds of tanks and wheels and anything else you can think of thats aluminum!
  13. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    They make buffing cones to mount on hand held grinders...9" and 4 1/2" ones...5/8 thread.
  14. monkeywrenching
    monkeywrenching
    from maryland
  15. jeffgies
    jeffgies
    Thanks for the ideas. I'm pretty sure my keg is stainless steel, so a little more rubbing to get it nice and shiny.
  16. alchemy
    alchemy
    Empty the keg first. But wait a few hours before holding it up to the buffer.
    Edit: I just saw you're from Canada. You'll probably only need to wait one hour.
  17. charlieb66
    charlieb66
    Maybe not for your case, but buffing wheels can be mounted in place of a table saw blade. This would provide a large surface to rest parts.
  18. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    I doubt that the keg is stainless but if it is you want to use a Sissal buffing pad first with the black compound followed up by a loose buffing pad with white or green compound. EH.
