Projects Plymouth 1953 hardtop
Discussion in 'Traditional Customs' started by Moparguy_bmx, Oct 15, 2017.
  1. 48fordnut
    48fordnut
    Ltd ,wheels fit and they are wider.
    Keep up the good work, stay warm.
    jim
  2. Back into the garage, using it is fun, real fun. What can I do to improve suspension w/o major mods?
    48fordnut likes this.
  3. plym_46
    plym_46
    from central NY
    You can relocate the front shocks to a frame mounted anchor using 50's Ford F1 mounts with some drilling and some spacer fab for the bolts going through the boxed section of the frame, you can replace your front springs with those from a Ford Aerostar van. If you want to lower it in front you can get a nearly 2 inch drop by repositioning the lower spring pockets to the bottom of the lower a arm, some grinding, measuring and drilling required. You can adapt an early rear wheel drive Cherokee (not Grand) sway bar. In the rear confirm all your leaf springs are intack,add gas shocks and renew the rear spring to shakle bushings, and make sure the shakle to frame mounts aren't ovaled out. Also give some thought to new rear motor mounts between the bell housing and cross member, keeps the engine from being involved with chassis movements and stiffens the frame against twisting. You can also consider going to a newer rear axle, Mopar B body, Cherokee, early five lug bolt Dakota for better and easier to maintain rear brakes seals and bearings, not to mention a more highway friendy gear set.
    Peanut 1959 and 48fordnut like this.
  4. Hey everybody, It's been a while since no posts. Brakes and suspension still stock. Put a Carfe carb (Argentinian Falcon carb) and it runs smoother and more efficiently. I did a long trip some weekends ago and when I was coming back I had to brake hard and maybe destroyed a seal on the non-driver rear wheel so I ran out of brakes, luckily nothing happened and I didn't crash. If u remember from early posts I have all new lines, linings even cylinders were bought new from oldmoparts. The thing is that I have a friend with a 4 door 53 too that today had the same issue and luckily didn't crash too, he stopped with a curb. I want to know if this is something common on these brake setups, he's got the car for 7 years and never happened that to him, he uses it as a daily with the 218 and everything stock. Is this something that happens because of adjustment?. I got a master cylinder from a 70's dart (double circuit, don't know how do you call that master setup) that I'm planning to use to avoid losing brakes if something fails. 82067577_1596620107158697_127151982812069888_n.jpg 71022184_1077330645803619_3765931490974629888_n.jpg 85004183_2730462977066235_1595312627972571136_o.jpg
    Yeah I know... it looks like a 54 from behind :)
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    You should be able to rebuild your wheel cylinders, and maybe rebuild them all if you think the seals that they came with might be defective.
  6. 48fordnut
    48fordnut
    Glad no one got hurt. Good to see you active again.
